Does NVidia gfx card on powerbooks work?
    Yasu
    Posts: 1724 from 2012/3/22
    Like the title says. I've found a 12" that I wanna buy (1,5 GHz model).
    My MorphOS blog
  • »19.09.13 - 10:53
    Posts: 1099 from 2004/9/23
    No, they don“t work!
    Geit
  • »19.09.13 - 11:11
    Yasu
    I didn't think so, but I got a little unsure when it wasn't mentioned in the "**" section. Thanks :-)
    My MorphOS blog
  • »19.09.13 - 12:33
    Posts: 2581 from 2003/2/24
    Even if NVidia was supported, their would be little benefit choosing that 12" PB 1.5GHz over the supported 12" iBook 1.33GHz
    - both only do 1024x768
    - neither has a cardbus slot (so no WiFi for the moment)
    - PB has 64MB VRAM over the 32MB in the IB, but at 1024x768 thats plenty
    - both use the suboptimal ADB keyboard
    - both come with good USB trackpad
    - the iBook can hold up to 1.5GB RAM, while the PB seems to be stuck at 1.25 (which is weird as it also have 512MB onboard RAM listed).
  • »19.09.13 - 13:30
    Yasu
    That may be true, but they seems to be easier to find here in Sweden than 12" Ibooks :-)
    My MorphOS blog
  • »19.09.13 - 13:57
