cant get morph to install on my powerbook g4 17"
    Posts: 45 from 2013/8/19
    md5sum is same
    disk@1 and just @1 work the same, tried both, I get the same result. Tried with and without a disc in, same result :-(
  • »15.09.13 - 13:41
    I've done it!
    I'm in, writing this in OWB on the installed version of MorphOS!
    Turns out the USB stick had a hidden partition that Windows and OSX couldn't see, removed it, reformatted and away I go!
    thanks for all the help guys!
  • »15.09.13 - 14:33
    boot_wb
    Posts: 874 from 2007/4/9
    mmace wrote:
    I've done it!
    Awesome :-)
    Glad you got it sorted in the end. Flaky optical drives don't make life easy.
    www.hullchimneyservices.co.uk
    Windows free since 2011!
  • »15.09.13 - 17:45
