MorphOS and backdoors/unauthorized remote access
    Jason
    Posts: 14 from 2009/11/6
    Does MorphOS contain any backdoors or other means for governments or the morphos team to gain unauthorized access/keylogging/spying?
    Since the whole NSA debacle I've become quite concerned over closed source software.
    Can the developers make any comments about this?
  • »31.08.13 - 18:51
    bash64
    Posts: 977 from 2010/10/28
    Yes,
    There are little green men installed along with a few gremlins with every copy of MOS.
    :-D
  • »31.08.13 - 20:32
    Seems highly unlikely.
    I doubt the development team would stoop to that.
  • »31.08.13 - 20:51
    Intuition
    Posts: 1116 from 2013/5/24
    http://cm.bell-labs.com/who/ken/trust.html
  • »31.08.13 - 21:13
    Piru
    Posts: 624 from 2003/2/24
    There are no backdoors or other means that I know of.
    That being said, the MorphOS source code is rather huge when you count all the 3rd party components, too. It would be extremely difficult and expensive to audit all of it.
    Also, it is possible that some of the MorphOS components may contain bugs that would allow remote attacker to cause crashes, and possibly execute code by means of a drive-by attack and/or specially crafted files. MorphOS is a very small platform however, and it can be said with high certainty that exploit writers are targeting some larger platforms.
    If you're worried about privacy and NSA snooping the most likely way you get snooped is use of internet services hosted in the US or provided by US companies (Google, Facebook, Twitter, LinkedIn etc). Also, most other countries snoop all network traffic crossing their borders (for example Sweden does this).
    Use of encryption for confidential and/or sensitive data is highly recommended. When sending email or browsing the web always consider the fact that someone might see everything you read and/or write. Use of TLS/SSL protected sites itself doesn't necessarily improve the situation as some service providers and companies themselves provide the keys to intelligence services per request.
  • »31.08.13 - 21:20
    Posts: 3336 from 2003/3/5
    Oh, I have to deal with this shit at work (data retention, wire-tapping for the government agencies) so I'd prefer not to have to do such stuff after work as well ;) Nope, MorphOS does not do anything like that, it does not even call home on its own.
  • »01.09.13 - 14:16
