.ics files
    xyphoid
    Posts: 870 from 2008/7/11
    So we keep pushing google docs in lieu of a native suite program or office productivity
    software. I downloaded my calender from google docs which was a zip file. unzipping
    created a .ics file. Is there a program which I can use to view it offline?
  • »28.08.13 - 23:43
    Posts: 1090 from 2004/9/23
    From what I can say there is none. There are some web tools, AFAIR, but that will not help for confidential/private data.
    I hacked together a small importer for my csv database tool, so a friend who needed to export all business calender information as text, was able to process the data. And there wasn´t a proper tool that did it without cloud processing or installing tons of tools on windows.
    However it was just a hack and is nothing I would release. Things like birthdays are handled differently and caused a broken entry. Since he just needed the other stuff, I never invested more time to find out how this format works. I never finished it, as you never know when google will drop something. However, it worked for him. :)
    Geit
  • »29.08.13 - 10:23
    boot_wb
    Posts: 874 from 2007/4/9
    Might also be worth asking Polymere (author of Polyorga) as he's likely to have looked into the format when making Polyorga.
    http://polymere.free.fr/Site_New/polyorga_en.html
    www.hullchimneyservices.co.uk
    Windows free since 2011!
  • »29.08.13 - 11:27
    xyphoid
    thanks anyways.
  • »31.08.13 - 21:03
