Something I would like on MorphOS / Ambient
    Yasu
    Posts: 1724 from 2012/3/22
    I thought an easy to search for wish list would be in place.
    One thing I miss is when I look for files in the drawers and press "date", it doesn't show the date of when the file was moved to that drawer (like my Windows setup) but rather ... something else.
    This is quite annoying when I look through my Download drawer and want to be able to quickly access my latest downloads.
    So I want to propose a "last changed" button to add to the existing ones. That is, every time something in that file change it goes to the top (new files, changed document etc). Would make my MOS life easier anyway :)
    My MorphOS blog
  • »08.08.13 - 11:09
    Yasu
    And on another note: when I choose "Filetype" as list mode, the files are listed correctly as filetypes but not in alphabetical order.
    My MorphOS blog
  • »08.08.13 - 11:43
    Krashan
    Posts: 1107 from 2003/6/11
    You have to click on the column header to have them sorted.
  • »08.08.13 - 13:38
    Posts: 2217 from 2003/2/24
    Maybe he means that when you sort them with filetypes, files with same filetype aren't in any particular order... maybe it would be more clear to have them "sub sorted" indeed.
  • »08.08.13 - 14:06
    Yasu
    @jPV
    Yes, that is what I meant.
    My MorphOS blog
  • »08.08.13 - 14:46
