Window frame styles configurable?
  • Visitor
  • Is it possible to change the window styles in Morphos to make it look like other OS's/GUIs?
    Thanks!
  • »05.08.13 - 15:11
    Posts: 12539 from 2003/5/22
    "Settings" -> "System" -> "Screens" -> "Edit" lets you select the skin for the selected screen. The download section of this very site (aka morphos-files.net), Aminet etc. have many more, among them ones that resemble the look of different AmigaOS versions.
  • »05.08.13 - 19:03
    Intuition
    Posts: 1116 from 2013/5/24
    I use Simply Black from here.
    http://korni.ovh.org/morphos-skins/
  • »05.08.13 - 20:38
    Intuition
    This is a nice one too.
    http://www.five-star.com/kens_icons/downloads/imaz_MOS.lha
  • »05.08.13 - 20:40
    Intuition
  • »05.08.13 - 20:41
    analogkid
    Posts: 719 from 2004/11/3
    There are also different skins on MorphOS-Files.net:
    http://www.morphos-files.net/categories/system/graphics
    In my eyes, skin support is one of the key features of MorphOS. I wouldn't love it that much if I were limited to the default Ferox skin.
  • »06.08.13 - 04:39
