Clock battery on G5
    Yasu
    Posts: 1724 from 2012/3/22
    When I remove the power cord the internal clock resets immediatly, even after such a short time as 1 second.
    I want to rule out any other reason then that the clock battery has died. Maybe that this is normal for the G5 or a MOS bug or something. Have any one else experienced this?
    And if it is a broken battery, could it be a sign of severe leakage?
    My MorphOS blog
  • »09.07.13 - 15:57
  • esc
    esc
    Posts: 160 from 2013/5/27
    Same issue here.
  • »09.07.13 - 16:19
    Jambalah
    Posts: 820 from 2008/3/30
    I presume your battery expired (or lost alot power) since G5 has not rechargeable battery like Pmac G4.
    And no, it's not a sign of leakage. Unless it's an old barrel battery (remember Amiga batteries?)
    [ Edited by Jambalah 09.07.2013 - 20:31 ]
    Pegasos II 1 ghz
    Powermac G5 dual 2.0 ghz
    Powerbook G4 1.67 ghz 17
  • »09.07.13 - 16:28
    Intuition
    Posts: 1116 from 2013/5/24
    Just add SetClockNTP to your network-startup.
  • »09.07.13 - 16:41
    Yasu
    That makes a lot of sense! Thanks everybody for the input and suggestions :-D
    My MorphOS blog
  • »09.07.13 - 17:11
    Posts: 2581 from 2003/2/24
    The battery is the same type as in the G4s (atleast in my QuickSilvers), non-rechargeble, can be hat at ebay for few € / $.
  • »09.07.13 - 17:13
    tolkien
    Posts: 585 from 2013/5/29
    Same problem here. I 'll search in ebay to change it.
  • »09.07.13 - 18:28
