Flawless 3.2 upgrade thread - post here if it went well!
    rebraist
    Posts: 96 from 2011/4/6
    Perfect installation. Only issues: on pwbook 5.6 I had some lags when using scribble. And i don't know how to create a panel...
    Yes and now my mobile router won't work: when i plug the ethernet cable there's no way nor to ping it nor to use it. If i use it, using the same pwbook, in osx all goes fine. But if i connect it to the wired internet morphos works good.
    [ Edited by rebraist 06.06.2013 - 13:58 ]
    Sam440 Os4.1.6
    Aros-Aros-Aros.
  • »06.06.13 - 09:55
  • JKD
    JKD
    Posts: 456 from 2003/4/4
    Flawless upgrade from 3.1 to 3.2 on 15" PB 5,8.
    It's a shame the 3d stuff is bugged, can't open any 3d games because the rave3d library open fails for some reason :-/
    The only 3d stuff that seems to work is the gl screensavers.
  • »14.06.13 - 15:51
    Posts: 12498 from 2003/5/22
    It's a feature, not a bug ;-) See explanation there:
    https://morph.zone/modules/newbb_plus/viewtopic.php?topic_id=9256&forum=49&start=4
    As you can see, this should only be the case for Warp3D games, definitely not "any 3D games".
    Everything that uses TinyGL should work essentially.
  • »14.06.13 - 20:38
    scrAb_
    Posts: 62 from 2010/7/23
    Just installed from scratch on PB 5.9 and updated my mini 1.5.
    Everything went smooth, but I noticed the update didn't upgrade to OWB 1.20...
    is it ok? I don't think so....:-(
    MacMini@1.5Ghz 1GB/DualBoot Morphos3.1/DebianPPC - Efika MX sb
    PowerBook 5,9
  • »04.07.13 - 04:57
    Doffo
    Posts: 508 from 2010/10/14
    scrAb_,
    Usually I just have Grunch installed to be sure programs are up to date.  8-)
    YUUUP!
  • »04.07.13 - 11:38
    I have not yet installed any software, but the installation of MorphOS3.2 on my 17-inch 1.67GHz G4 PowerBook went smoothly and without any problems on the first try. I am debating with myself about installing Chrysalis, or instead just installing Grunch and choosing which software and settings I want.
    On my Dual 2.7GHz G5 PowerMac tower I am only seeing a black screen without any indication that anything is happening when I try to boot from the same MorphOS3.2 installation CD, so I can't claim the same flawless installation on that system (Yet).
  • »05.07.13 - 19:43
