rexx
    bash64
    Posts: 974 from 2010/10/28
    I keep getting the 'rexxsyslibrary' error when I run a rexx script.
    I have rexxsyslibrary installed in Libs:
    What gives?
    I also have a system folder with rexxmast from 68k.
    Please provide the proper steps to install rexx.
    Thanks
  • »04.07.13 - 09:48
    Posts: 2217 from 2003/2/24
    1. Rename MOSSYS:Libs/rexxsyslib.library to MOSSYS:Libs/rexxsyslib.library_disabled
    2. Copy 68k rexxsyslib.library to SYS:Libs/
    Done. You don't need any 68k rexxmast or other stuff.
  • »04.07.13 - 09:56
    bash64
    ok,
    Error message is gone.
    I am in Pagestream 3.
    I have created a text area.
    I launch the arexx script to open Pageliner.
    Pageliner opens on the same screen as PageStream, but it is just a window with a title bar and nothing else.
    I cannot type any text. There is no input area.
    Am I missing something?
    I can and will upgrade to the newest Pagestream if that will fix issues.
     :-D
  • »04.07.13 - 10:22
    bash64
    Great,
    Insert Text - no longer works. Can't even insert a text file into PageStream.
    Insert Graphic worked.
  • »04.07.13 - 10:36
    bash64
    Correction - it helps to not get old and rusty about how to do things. Insert text works if you do it right.
    However, Pageliner still does not allow editing for the above reasons.
  • »04.07.13 - 10:41
    bash64
    Wow,
    Pageliner finally came up, but it was a pop-under.
    I had to look behind the main DTP window to see it.
    Nevermind. Nothing to see here. Please move on.
  • »04.07.13 - 10:52
    Posts: 1090 from 2004/9/23
    bash64 wrote:
    Wow,
    Grunch also provides a proper rexx installation without any user affords.
    Geit
  • »04.07.13 - 11:03
    bash64
    Never noticed that!
    Ok, grunch being added as an option on my docs site.
  • »04.07.13 - 11:19
