G5 and internet problems
    Yasu
    Posts: 1724 from 2012/3/22
    Since yesterday my G5 2,7 GHz MOS system became unable to access the internet.
    I start OWB or Grunch and as soon as they start trying to load something from the net, the program freezes and must reboot. It also make other programs unable to load in the process. If I start OWB and don't try to load any HP everything works fine.
    I had some sort of prefs loading error just before this started as well.
    So, any ideas short of a full reinstallation?
    My MorphOS blog
  • »25.06.13 - 08:18
    stephen_robinson
    Posts: 746 from 2007/4/22
    Can you ping www.google.com or 8.8.8.8 or 127.0.0.1?
  • »25.06.13 - 08:28
    Yasu
    How do I ping? With Shell?
    My MorphOS blog
  • »25.06.13 - 08:57
    Yasu
    Now I' experiencing the same lockup when I try to access prefs and other programs. I believe now that some prefs program have bern corrupted. Where do I find them so I can delete them?
    My MorphOS blog
  • »25.06.13 - 09:23
    _ThEcRoW
    Posts: 298 from 2008/10/27
    If your g5 is liquid cooled, check that is getting the correct refrigeration. IF the temperature is too high, it could lead to symptoms like the ones you described.
    You said that your g5 is a 2.7, so it must be a liquid cooled, so check it out asap.
  • »25.06.13 - 11:06
    pampers
    Posts: 1071 from 2009/2/26
    Sounds like HW related problem, overheating or hard drive failure. Try to boot MorphOS from CD and check if you get the same symptoms?
    MorphOS 3.x
  • »25.06.13 - 11:58
    bash64
    Posts: 977 from 2010/10/28
    This is WHY I am going with heatsinks instead.
    Proven 72c if you remove the LCS.
    See active cooling thread.
  • »25.06.13 - 12:23
    pampers
    You cannot generalize about that as my LCS cooled G5 makes me no trouble at all. It's just the matter of proper taking care of your HW.
    MorphOS 3.x
  • »25.06.13 - 13:14
    pampers
    MorphOS 3.x
  • »25.06.13 - 13:14
    Posts: 12570 from 2003/5/22
    Yes.
  • »25.06.13 - 17:06
    > I believe now that some prefs program have bern corrupted. Where do I find them [...]?
    MOSSYS:Prefs/MPrefs/
  • »25.06.13 - 17:07
    Yasu
    I can't do anything anymore. So I'm going for a full reinstall. Doesn't matter much since I haven't been able to do anything. But I'm not convinced that it's HW related per se, since it all started after a setting got corrupted somewhere. Up until then, everything has worked just fine.
    My MorphOS blog
  • »25.06.13 - 21:29
    Yasu
    A fresh reinstall seems to have worked. Internet works again and the random freezeups are gone. Let's hope it stays :-)
    My MorphOS blog
  • »26.06.13 - 06:21
