Fried SFS partition - How do I get my key file back?
    matt3
    Posts: 771 from 2004/2/10
    User error I selected new install and blew away my keyfile.
    How do I get it back?
    Thanks!
    Matt
  • »18.06.13 - 14:00
    vulture
    Posts: 195 from 2008/2/4
    I think you can email the morphos team with your details and they'll resend you the key - not sure though.
  • »18.06.13 - 14:05
    Posts: 2202 from 2003/2/24
    matt3,
    Don't you have any backup of it? Even the email it originally came with? You should always backup your keyfiles and other registered stuff to several places.
    But anyway, contacting to MorphOS team should solve the issue...
  • »19.06.13 - 03:19
    analogkid
    Posts: 712 from 2004/11/3
    A practicable solution is to inject the MorphOS key via RegisterISO into the MorphOS ISO and burn it on a CD. This will provide you with a very good emergency Live CD for rescue or backup purposes, and it's registered.
    Source: http://www.geit.de/deu_additional.html
  • »19.06.13 - 03:38
