Curious: 1080-movies and G5
    Yasu
    Posts: 1724 from 2012/3/22
    I want to know how much processing power is being used on different G5 systems when watching full HD (1080p) movies. I've read that the 2,7 GHz uses around 35%. How about the rest?
    My MorphOS blog
  • »05.06.13 - 13:22
    Posts: 12454 from 2003/5/22
    The workload depends heavily on the used video codec. More info:
    https://morph.zone/modules/newbb_plus/viewtopic.php?forum=11&topic_id=8313&start=45
  • »05.06.13 - 13:41
    Doffo
    Posts: 508 from 2010/10/14
    Currently have a passive cooled 2.7ghz setup. I couldn't get a 1080P to work full speed. The same video at 720P played, but takes about 50% of the CPU the entire time.
    YUUUP!
  • »05.06.13 - 22:54
    boot_wb
    Posts: 874 from 2007/4/9
    And especially bitrate (and probably number of reference frames, and no doubt some other voodoo video encoding stuff).
    www.hullchimneyservices.co.uk
    Windows free since 2011!
  • »05.06.13 - 23:49
    bash64
    Posts: 959 from 2010/10/28
    Any paticular version of mplayer that runs faster than the others?
    Any video player capable of playing h.264 besides mplayer?
  • »06.06.13 - 00:00
  • Fab
    Fab
    Posts: 1331 from 2003/6/16
    You won't get faster than MPlayer on MorphOS. And the latest version is the fastest (4% faster than the previous one).
    And there *is* h264 1080p contents that plays just fine on G5. http://www.dvdloc8.com/clip.php?movieid=12167&clipid=3 for instance.
  • »06.06.13 - 06:13
    number6
    Posts: 487 from 2008/8/10
    Bitrate indeed.
    What about encoding from uncompressed source vs re-encoding from an A/V file previously compressed?
    This can get quite complicated when trying to reduce it to a simple phrase like "1080p plays".
    #6
  • »06.06.13 - 13:11
