Any MOS 3.0 screenshots?
    NewSense
    Posts: 1576 from 2012/11/9
    Fab wrote:
    You can also use SGrab if you really like it.
    I tried to use SGrab, but it asked for the jpeg.library to be installed, and then for me to close the SGrab application, and try again, which I did, and got the same reply.
    There is a jpeg.library in MOS3.2 on startup, but I replaced it with the later releaase which is 68k based, by Paul Huxham that he did for Photfolio, but that made no difference either - same error message.
    When I tried to save the screengrab as an ILBM the screeen flashed, and I got the 'sound effect' that there'd been a failure to complete my request, and the same again when I tried to save the grab as a PNG.
    Anyone actually used SGrab under MOS3.x, and know what is the cause of the grabbing application not working correctly.
    I really like SGrab, as you can grab a section of a page, even just a small image or piece of text, wheras SnapIT only grabs the page/window, and I don't know of any other grabber that offers as many choices as SGrab in a screengrabber.
    So it's a pity it's not working under MorphOS 3.2 from the basic installation/updated setup at the moment.
    [ Edited by NewSense 06.06.2013 - 18:17 ]
    MacMini 1.5GHz,64MB VRAM, PowerBooks A1138/9 (Model 5,8/9),PowerMac G5 2.3GHz(DP), iMac A1145 2.1GHz 20", all with MorphOS v3.19+,Airport,Bluetooth,A1016 Keyboard,T-RB22 Mouse,DVD-RW-DL,MiniMax,Firewire/USB2 & MacOSX 10.4/5
  • »06.06.13 - 01:10
