iBook issues
    ciVic
    Posts: 45 from 2013/6/2
    Hi all,
    yesterday I have bought MorphOS for my new old iBook. First I have to say, I love it! Fastes OS I have every seen (besides Amiga OS ;-) ) and it is great to be able to get the original Amiga look back (after some configuration ;-) ).
    But I have two issues:
    First, on my german keyboard I have a hash key (#). But pressing it gives me |. There is no way to get the hash (besides using the utility Keystroke). That is annoying when writing C ;-).
    Second problem is my network. Sometimes it does not get a connection to my ethernet, not even an IP. After one or two reboots everything is fine.
  • »02.06.13 - 06:57
    Posts: 1932 from 2003/10/19
    With several members in Germany I am sure this will be worked out very quickly.
  • »02.06.13 - 09:27
    ciVic
    If there is a doc how to read out the character codes and how to edit a keymap maybe I can help.
  • »02.06.13 - 09:52
  • rNx
    rNx
    Posts: 35 from 2010/10/26
    Im having similar issues with iBook and Finnish keybord. Last time I checked, there was no public tool to create keymaps.
    Other issues Im having, iBook is running constantly at 50C and the wrist area is uncomfortably hot. Touchpad is not working, I have to use ShiftClick. Keeping the modifier down when clicking menu item do nothing. I have to release the modifier before clicking.
    Panels deadlock the system with 100% cpu when double clicking the zipping button. Dragging panels to last position in ambient prefs it not working. Speaking of Ambient prefs, "Get from window" window setting is still not workin. I think I reported that bug 2 releases ago.
  • »02.06.13 - 15:25
    Posts: 2095 from 2003/6/4
    Is the keyboard an usb or adb keyboard. If usb, you can easily change keybindings within Poseidon's preferences (Poseidon->Devices-Keyboard). For ADB keyboard's I think that Geits MMKeyboard tool could do the trick, but don't know (my powerbook has an usb keyboard), its original intention is to define hotkeys for actions not for characters.
  • »02.06.13 - 18:22
    redrumloa
    Posts: 1424 from 2003/4/13
    @ciVic
    Welcome to Morphzone and to MorphOS! 8-)
  • »02.06.13 - 19:03
    Henes
    Posts: 507 from 2003/6/14
    rNx,
    MorphOS' keymaps are opensource. You can grab the current sources at http://www.morphos-team.net/downloads
    More specifically the file http://www.morphos-team.net/files/src/3.2/keymaps.tar.bz2
    Then you are able to change them and eventually submit a fix. Or just create a new keymap.
  • »02.06.13 - 20:25
    ciVic
    Looks good. But compiling fails because it needs an makefile.global. Maybe I need something that is not open source?
  • »03.06.13 - 17:21
  • rNx
    rNx
    Zylesea,
    Not listed in Poseidon, so its ADB.
    While finding out the rawkey values I noticed LSHIFT + RSHIFT ($0060) and LAMIGA + RAMIGA ($0066) gives the same rawkey. This can't be right?
  • »03.06.13 - 17:46
    Posts: 1099 from 2004/9/23
    rNx
    It is correct this way. There is no left amiga. As both ADB keys deliver the same value, it is impossible to find out if the left or right was used. The right one is the most use (menu hotkey), so we took that one.
    Thats the reason why the normal reset combination is not working, but there is the power button as replacement.
    Geit
    [ Edited by geit 03.06.2013 - 22:36 ]
  • »03.06.13 - 18:33
    Intuition
    Posts: 1116 from 2013/5/24
    rNx,
    Have you tried this?
    http://aminet.net/package/util/misc/keymorpher_1.1
  • »03.06.13 - 19:44
    ciVic
    Great, using keymorpher I was able to change the keymap accordingly. Thx!
  • »05.06.13 - 06:49
