b.o.c.h.s. update surprise
    bash64
    Posts: 977 from 2010/10/28
    With the release of MOS 3.2 came a new TCP/IP stack and Berkley packet filtering.
    Thore says this is what was needed to get network emulation going inside of b.o.c.h.s. and is looking into finally turning it on. I believe he already had the code written.
     :-D
  • »01.06.13 - 20:02
    Intuition
    Posts: 1116 from 2013/5/24
    Is Bochs for MorphOS faster than DOSBox?
  • »01.06.13 - 22:00
    bash64
    Well, I am running windows xp pro with it.
    It runs at a decent speed.
    I think an ssd for a boot drive would help speed it up.
    You;d have to lookup my instructional thread on setting it up and install dos.
  • »01.06.13 - 22:24
    Posts: 12570 from 2003/5/22
    No.
  • »01.06.13 - 23:15
    Intuition
    I'm only interested in running DOS so I'll use dosbox then. Thanks.
  • »01.06.13 - 23:35
