Does MorphOS having sliding windows or workspaces ?
    macsociety
    Posts: 57 from 2010/1/18
    Coming from Amiga I like the sliding window where I can say have OWB open in its own window and slide the window down to access Workbench again.
    Does MorphOS 3.1 have this sliding window feature?
    If not, can one make workspaces so I can have apps open in certian windows and easily toggle between them?
    TJ
  • »07.02.13 - 22:43
    Posts: 12570 from 2003/5/22
    I take it you mean 'screen' when you say 'window' here.
    No, MorphOS can't do screen dragging the way you'd like it.
  • »07.02.13 - 22:52
    Miky060
    Posts: 694 from 2003/2/24
    You can add a sort of sliding screen feature using the "Dragon" app.
    Yes, you can open apps in different SCREENS and make this behaviour the default one. For example here OWB opens always on its own screen. You can also set a shortcut to switch between screens. Default one is amiga + M, I added middle mouse click as short cut to do this about 20years ago :-D
    [ Edited by Miky060 08.02.2013 - 06:12 ]
  • »08.02.13 - 03:08
    Posts: 2220 from 2003/2/24
    macsociety,
    Your terminology definitely isn't coming from Amiga ;) On Amiga and MorphOS there are screens which can have windows inside them. Screens can be on different resolutions (but mostly "fullscreen") and with native chipsets from Amiga you can also drag them vertically to view other screens. Some RTG solutions can also give you drag option, but traditionally it isn't used that much with RTG screens, because it slowed down normal switching between screens.
    Traditionally full screen Amiga programs have opened their own screen itself (like games and older apps) without even having possibility to config it, but newer apps usually have screenmode preferences where you can select on which and which kind of screen they run. Some programs can run on Workbench (=Ambient) screen or their own custom screen.
    MUI programs (the most of MorphOS programs) have a little bit different approach. MUI has own screen database, which has a list of predefined screens. Use can add as many different screens as he wants there. Any MUI program can then be moved to any screen defined in that database, temporarily or saved to go on that screen always.
    You can define separate screens for separate programs, for example add OWB screen and config OWB to use that screen always... and add ShowGirls screen and config ShowGirls to use that screen. If you then launch those both programs, you'll have three different screens open (Ambient, OWB and ShowGirls) and can jump between them by pressing command-m from keyboard or clicking screen depth gadget in top right corner of the screen (if you right click it you'll get list of all open screens and can select which one to switch).
    You can also collect bunch of programs to one common screen. For example define all internet software to use screen made for them. Simply configure separate programs to use same screen and snapshot all program windows to positions you want them to be on that screen. That way you can group your software on different "workspaces" as you'd say :)
    In MorphOS you can also create new screens for MUI programs more easily, without going to edit database settings. If you have popup menu button enabled for MUI programs, you'll see Jump to Screen option in that menu. There you can select if you want to create new screen for the program or move the program to some already configured screen. It's really easy to move program between the screens with just that popup gadget found in window titlebar. So, with OWB for example... open OWB, click popup button, select "Jump to Screen -> New", maximize OWB window for full screen (easiest if you have defined some way to maximize windows in IControl) and finally if you want to OWB always opening that way automatically click popup gadget again and select Snapshot to save window size and then select MUI settings and Save to save screen setting.
    For permanent use it's better to manually configure screens to database instead of using that automatic screen creation, because automatic screen creation opens screens in enhanced mode always and that wastes quite much graphics memory. For example OWB screen is just good without enhanced display setting, it's probably even faster without it. And you'll save the precious graphics memory for more screens. If you run out of graphics memory, you'll get slowdowns with screen switching, window opening/resizing etc. So it's better not to waste it when you don't need it.
    [ Edited by jPV 08.02.2013 - 08:28 ]
  • »08.02.13 - 04:22
    Posts: 1390 from 2010/1/6
    There is another amazing way to jump between screens: Try the commodity-program SCUBE. This gives you a "Desktop-Cube", as known from Linux.....
  • »08.02.13 - 05:30
    catohagen
    Posts: 297 from 2003/5/20
    macsociety,
    The Dragon utility by ultragelb/#amigazeux does give you vertical and horizontal screen dragging, but also dragging around screens(!) as they where windows, even screens with different resolutions, (drag a 1024x768 screen onto higher resolution screen)
    When Dragon was released, I made a short video to show the utility
    http://www.youtube.com/watch?v=p44mWKSjvLw
    but i honestly cant remember if the version in the video had more stuff enabled than the released version.
    Screendragging was always possible on classic 68k system, but MorphOS got screendragging some time before AmigaOS4.
    [ Edited by catohagen 08.02.2013 - 10:23 ]
  • »08.02.13 - 07:23
    >> [...] slide the window down to access Workbench again. Does MorphOS 3.1
    > screen dragging, [...] but i honestly cant remember if the version in the video
    IIRC the released version allows to view the back screen and to completely switch to it but doesn't allow what the thread opener seems to ask for, i.e. access to the back screen while the front screen stays partly dragged, because as soon as the mouse button is released, the front screen jumps back to its original position.
  • »08.02.13 - 09:36
    catohagen
    Andreas_Wolf,
    Ok, clearly the version used in the video didnt have this limitation, as both visible screens are interacted with while one is being placed partly offscreen...
  • »08.02.13 - 12:32
    Yes, I know. Thing is that the thread opener probably can't use this non-released version ;-)
  • »08.02.13 - 13:09
    Jambalah
    Posts: 820 from 2008/3/30
    It's explained here:
    https://morph.zone/modules/newbb_plus/viewtopic.php?topic_id=7922&forum=3#84729
    Post #11 by Itix. The version used for the video is Dragon 2, never finished.... =(
    Pegasos II 1 ghz
    Powermac G5 dual 2.0 ghz
    Powerbook G4 1.67 ghz 17
  • »08.02.13 - 13:18
    Posts: 2732 from 2003/2/24
    [ Edited by takemehomegrandma 08.02.2013 - 18:54 ]
  • »08.02.13 - 15:52
    macsociety
    jPV,
    You are correct, sorry for my typo.
    I was too fast to type and not thinking properly at the time.
     :-D
    Thanks to all for the notes about Dragon and other options. I will check them out.
    TJ
  • »08.02.13 - 17:07
    macsociety
    Too bad I can't seem to find this Dragon app. Would be sweet to screen drag on the MorphOS Mac Mini.
    I take it this Dragon app is no longer available anyplace? TJ
  • »30.05.13 - 19:56
    Henes
    Posts: 507 from 2003/6/14
    Try http://amigazeux.org/index.php?module=News&type=user&func=display&sid=43
  • »30.05.13 - 20:00
