First Issue - PM G5 - MOS 3.2
    SteveE617
    Posts: 80 from 2013/1/26
    Had my first issue...not sure if its the G5 or the OS.
    Upon boot up the system slowed to a crawl. Slow to boot, very jerky mouse cursor movements, slow for Ambient to appear, slow icons...when the system finally got up and running. I got a mdialog box the the BSDSocket was missing. I rebooted, the system booted at normal speed, but still got the BSDSocket message. Rebooted one more time, system was a crawl...keep in mind...I'm running just the OS. I haven't put any add-ons on the machine.
    Reinstalled the OS from scratch, had no problems. Posting this using the G5 and OWB.
    Anyone else experience this?
    [ Edited by SteveE617 28.05.2013 - 12:50 ]
    Steve E, BSOE, MIS
    PowerMac G5 | Dual 2.0 Ghz | 2 GB | 32GB CF | 9800XT
    AmigaOne x5000 | 8 GB | 1TB | Radeon 7770HD
  • »28.05.13 - 15:49
    SteveE617
    zucow: If it happens again I will check the debug.
    Thanks for your response.
    Steve E, BSOE, MIS
  • »28.05.13 - 15:52
    SteveE617
    Reinstalled OS. Works great after immediate reboot. Surfed the internet with OWB. Shut down.
    Turned on the machine again..Slooooooow. Jerky mouse movements, icons slow to appear, overall system performance is slow and choppy.
    Any thoughts???
    Steve E, BSOE, MIS
  • »29.05.13 - 01:22
    Posts: 2220 from 2003/2/24
    Check the debuglog. Enable Debug screenbar module (rmb over screen depth gadget) and select Show Log from appearing screenbar item. If it has something that would explain the issue, file a bug report from MorphOS's about window.
  • »29.05.13 - 02:45
    Posts: 2581 from 2003/2/24
    How does the G5 handle under OSX (or Linux) ?
    Are the fans running louder than ?
  • »29.05.13 - 08:07
    SteveE617
    Kronos:
    MacOS X.4.11 runs without any problems. Fans run normally.
    In MOS 3.2 the fans run a little bit louder.
    Steve E, BSOE, MIS
  • »29.05.13 - 10:33
    Intuition
    Posts: 1116 from 2013/5/24
    SteveE617,
    Any thoughts???
    I have more or less the exact same problem on my Powerbook 5,8 after upgrading to 3.2.
    I renamed the MOSSYS: folder and restored the backup of the 3.1 folder, rebooted and still have the same problem, so I renamed Boot:boot.img and restored the backup of the 3.1 boot.img rebooted and everything works perfectly. No lockups, no jerky mouse movements etc.
    Any ideas?
    I will have a look in the debug logs to see if I can see anything obvious.
    [ Edited by Intuition 29.05.2013 - 14:25 ]
  • »29.05.13 - 11:24
    eastone
    Posts: 47 from 2007/8/4
    I have quite same problem on G4 MDD with Radeon 9800XT
    My log looks like this:
    DRIVERIO_EVENT: spurious eventmask 0x40000000..no ObjectData
    DRIVERIO_EVENT: IntSignalMask 0x40000000
    Radeon: Timeout while waiting for the DMA CCE queue to idle
    Radeon: DMA RPTR: 00000800, RPTR: 00000800, write index: 00000900, WPTR: 00000900
    Radeon: DMA RPTR: 00000800, RPTR: 00000800, write index: 000009d0, WPTR: 000009d0
    WaitForIdle timeout!!! Access type: 00000002 RPTR 0x800 WPTR 0x9d0 RBBM_STATUS 0x80010140, CP_STAT c0000204
    HW acceleration disabled due to fifo timeout
    Once i had luck to run glxgears and I had 50FPS more than Radeon 9000, so difference is not so big :)
  • »29.05.13 - 11:50
    pampers
    Posts: 1071 from 2009/2/26
    Is your radeon flashed? Afair - yes.
    MorphOS 3.x
  • »29.05.13 - 11:56
    Intuition
    The only messages in the debug log were regarding Helios so I used Grunch to uninstall it as I don't currently have any Firewire devices plugged in.
    After a reboot 3.2 is working perfectly so far after almost an hour of use.
    Perhaps removing Helios might help others?
  • »29.05.13 - 12:37
    Miky060
    Posts: 694 from 2003/2/24
    Still no news about this issue? I would like to be able to use MorphOS on my Powermac G5..
  • »29.05.13 - 15:20
    pampers
    Did you already installed 3.2 on your G5?
    MorphOS 3.x
  • »29.05.13 - 15:41
    Miky060
    Yes, but I can't use it!
  • »29.05.13 - 15:41
    pampers
    Very 'detailed' description of a problem.. 1st question - what is going on wrong, 2nd question - what is your gfx card.
    MorphOS 3.x
  • »29.05.13 - 15:54
    eastone
    What is wrong with flashed cards? I dont have any problems under linux and osx.
  • »29.05.13 - 16:05
    Miky060
    @pampers
    Sorry, I described config and problem in another thread. I did not repeat it here because it seems it's a common problem between G5 users..
    Same problem of Steve and others: "Upon boot up the system slowed to a crawl. Slow to boot, very jerky mouse cursor movements, slow for Ambient to appear, slow icons.."
    My GFX board is a 9800XT (genuine MAC version, not a PC flashed one).
  • »29.05.13 - 16:17
    pampers
    @Miky060
    There is too much threads recently, definitely ;) I have 9800XT as well but in 2D I have no probs at all. With 3D there is a problem which is known to Bigfoot. To be honest I thought that you have flashed radeon but if it's a proper Mac version you probably need to hold on for a fix.
    @eastone
    I think that was already discussed in here (Andreas might come with some links soon ;) but just a quick question - how many people are (or were) developing gfx drivers for Linux and OSX...
    [ Edited by pampers 29.05.2013 - 19:25 ]
    MorphOS 3.x
  • »29.05.13 - 16:23
    eastone
    @pampers
    But morphos developers are more clever? ;)
    I think they can do that ;)
  • »29.05.13 - 16:33
    Miky060
    @pampers
    so do you think the problem is the GFX Board? If I take the 9000Pro from the Powermac G4 MDD can I fit it in my G5 and use it until they fix the problem? I also have a Flashed 9800XT that I could try. If I use this do I have to remove the tape I used to disable pins 3 and 11 or can I just fit it and try in AGP4X mode?
    The problem can't be connected to the Ram modules (6GB if I remember correctly) or the fact that I use PFS3 filesystem on all my partition (500 buffers for every partition) apart the boot one (HFS)? Don't kill me if I've told stupid thinks..
    [ Edited by Miky060 29.05.2013 - 21:03 ]
  • »29.05.13 - 16:57
    Posts: 12570 from 2003/5/22
    https://morph.zone/modules/newbb_plus/viewtopic.php?topic_id=8583&forum=11&start=12 :-)
  • »29.05.13 - 18:21
    pampers
    @Miky
    Radeon 9000 won't fit into G5's AGP. You might try with the reflashed to be able at lest work in 2D environment. Dunno about PIN taping, it's not needed for G5 so better remove the tape.
    I don't think that PFS3 or 6GB RAM makes any difference.
    MorphOS 3.x
  • »30.05.13 - 04:43
