MorphOS Developer
Posts: 3311 from 2003/3/5
That's a real shame. What is the reason it's hard to implement? I mean, considering that it works on other models with similar gfx cards.
Similar != the same. You can't just throw a different screen resolution at the LCD panel, you have to scale the picture instead. And proper DVI out support requires dual-head support which we do not have.
