Bugs: Graphic glitches on Raderon 9200
    Yasu
    Posts: 1724 from 2012/3/22
    I have a Mac Mini 1.25 ghz with Radeon 9200. Whenever I reboot the computer or do some changes in MUI I get some gray stripes on some of my desktop icons (usually SYS: and sometimes also DH2:). And also, Polynet (the bar that comes with Pack Chrysalis) can't handle transparancy. I don't know if these problems are related, but I thought I should report it anyway.
    My MorphOS blog
  • »22.05.13 - 19:24
    Posts: 1099 from 2004/9/23
    Thats a known issue. It is some random memtrash.
    Probably already gone with all the recent MorphOS 3.2 changes.
    The good news are that it is harmless and not a hardware problem.
    Geit
  • »22.05.13 - 20:02
    Yasu
    Sounds good! Does that include the transparancy problem?
    My MorphOS blog
  • »23.05.13 - 08:53
    Well, I don´t have any idea about polynet, but it sounds like it is using so called "fake transparency", which may cause trouble if implemented wrong as well as may be fooled by the user moving a window underneath.
    Anyway, MorphOS 3.2 comes with a new panel system that supports real transparency.
    Geit
  • »23.05.13 - 10:22
    Ingo
    Posts: 103 from 2004/3/19
    Hmm. Does that mean old panels won't work anymore or what do you mean with new panel system?
  • »23.05.13 - 17:12
    The ambient panels from pre 3.2 will be upgraded with new features. You probably don´t see any difference, when using you old config.
    Other thrid party panels will work as before.
    Geit
  • »23.05.13 - 17:57
    Posts: 12570 from 2003/5/22
    Some past mentions of it:
    https://morph.zone/modules/newbb_plus/viewtopic.php?forum=3&topic_id=7532&start=1
    https://morph.zone/modules/newbb_plus/viewtopic.php?forum=9&topic_id=8121&start=28
    https://morph.zone/modules/newbb_plus/viewtopic.php?forum=3&topic_id=8209&start=74
    https://morph.zone/modules/newbb_plus/viewtopic.php?forum=3&topic_id=8817&start=34
    https://morph.zone/modules/newbb_plus/viewtopic.php?forum=9&topic_id=8889&start=6
    https://morph.zone/modules/newbb_plus/viewtopic.php?forum=3&topic_id=8904&start=6
    https://morph.zone/modules/newbb_plus/viewtopic.php?forum=3&topic_id=8981&start=17
  • »23.05.13 - 18:41
    Yasu
    Wanted to just point out that this problem is still there after updating to 3.2. Nothing important, but a little annoying.
    My MorphOS blog
  • »28.05.13 - 08:57
    Can you try the following?
    Open Ambient preferences
    Select pictograms
    and now check the mode cycle at the bottom half of the window.
    What does it say? And does the effect vanishes if you change it to e.g. normal.
    Geit
    [ Edited by geit 28.05.2013 - 13:03 ]
  • »28.05.13 - 09:02
    Yasu
    I can't say for sure yet, but it appears to have done the trick. I'll get back if the problem return. Thanks :)
    My MorphOS blog
  • »28.05.13 - 09:29
    Which option triggered the issue?
    Geit
  • »28.05.13 - 10:03
    Rats
    Posts: 33 from 2013/1/22
    geit,
    Hi how do I find the pictograms option
  • »28.05.13 - 21:10
    'Icon display' is what geit means.
  • »28.05.13 - 21:23
