GMplayer: fullscreen still shows menu
    Yasu
    Posts: 1724 from 2012/3/22
    The latest version of MPlayer works grest! But when I try GMplayer and go fullscreen the menu won't go away, which naturally is quite annoying. Ordinary MPlayer doesn't have this problem.
    Is there something I can do to correct this or is it a bug?
    My MorphOS blog
  • »21.05.13 - 10:37
  • Fab
    Fab
    Posts: 1331 from 2003/6/16
    There's been no change at all in that regard, so it didn't appear with this version. Menu is not supposed to be shown, but it's not explicitely told to be hidden. So my guess is you deliberately decided to show menu in MUI settings (menu), in which case you might want to disable that.
  • »21.05.13 - 11:09
    Yasu
    Thanks. I'll look into that.
    My MorphOS blog
  • »21.05.13 - 11:33
    Yasu
    Yep. That was the problem. Thanks  8-)
    My MorphOS blog
  • »21.05.13 - 20:00
    Doffo
    Posts: 508 from 2010/10/14
    Thanks Fab for your continued work! I use MOS more frequently as I only check some websites/see some videos/run emulators.  8-)
    YUUUP!
  • »21.05.13 - 22:17
    boot_wb
    Posts: 874 from 2007/4/9
    @Yasu
    fyi - middle mouse button also toggles the menu display in fullscreen mode.
    www.hullchimneyservices.co.uk
    Windows free since 2011!
  • »22.05.13 - 09:01
    Yasu
    I tried that, but it sent me to the desktop screen instead. Is it a MUI setting?
    My MorphOS blog
  • »22.05.13 - 19:47
  • Fab
    Fab
    You probably have middle mouse button bound to screen cycle (or back to Ambient) event. I don't remember it's set by default, so you either set it or you use predefined settings like Chrysalis pack or so?
    Anyway, the behaviour can be changed in system preferences -> icontrol.
  • »23.05.13 - 11:16
