While waiting for my Peg....
    Ritty
    Posts: 29 from 2003/8/24
    Anyone out there to help me ??
    with windows 98SE, is sheduled tasks needed or can it be disabled, not sure what function is for ???? How DO I DISABLE IT?? Any help would be appreciated .... Lillian
    my peggy is back ordered from Ultraspec... but it maybe a while ... stuck with hand me down ..pc... meanwhile
  • »25.01.04 - 19:14
    MaSC
    Posts: 63 from 2003/12/1
    Sheduled tasks is for automatically running applications/utilities at set times, you can use it for running defrag at 8pm every sunday for example.
    So unless you need this feature, no it's not needed.
  • »25.01.04 - 19:25
    Ritty
    MaSC
    ty ..... now how may i disable it ???? or delelte it?
    Lillian
  • »25.01.04 - 19:28
    nels664868
    Posts: 117 from 2003/12/28
    Install Linux and erase wnidoze!
    Ask Dr. Stupid,
    Dear Dr. Stupid,
    Why do we have to go to school?
    That's a very good question. It's becuse your parents are
    ALIENS!!! When your at school they shed there human skins and
    breathe drier lint! hahahaha!
  • »25.01.04 - 19:37
    Ritty
    Nelson:
    Thanks for the reply but this is not my comp so i'm not in favor of doing such a thing...but if you have an answer on how to delete the scheduled tasks would love it hear it
  • »25.01.04 - 19:47
    Toto
    Posts: 268 from 2003/4/20
    @Ritty
    Open Task Sheduler and go to the advanced tab and select 'stop using Task Sheduler'.
    To delete sheduled tasks; right click on a task and select delete.
  • »25.01.04 - 20:07
    Ritty
    hello Toto:
    Thank you so much...that did the trick....You are a love....
    Lillian
  • »25.01.04 - 20:10
    poundsmack
    Posts: 1346 from 2003/6/8
    one more satisfied customer....
    "Poundsmack, official morphzone thread creator" -LorD
    "Wanna be lord of the avatars." -JKD
  • »26.01.04 - 08:26
