max memory under morphos 3.1?
    flea
    Posts: 17 from 2012/9/1
    Hi all.
    Playing with my PowerBook g4, and I've noticed that when the splash screen is displayed, it tells me that I have 1.667ghz power PC but only 1.5ghz of system ram. Is this normal? I have 2gb of system ram installed...
    Regards Lee
  • »12.09.12 - 17:06
    Posts: 1099 from 2004/9/23
    Around 1.5 GB is max. Thats normal.
    Memory addresses bigger than 2 GB are causing negative values which broken software, mostly 68K stuff, is handling wrong.
    The missing address space is used for system data and functions.
    Geit
    [ Edited by geit 12.09.2012 - 20:09 ]
  • »12.09.12 - 17:07
    ausPPC
    Posts: 543 from 2007/8/6
    Where does that system data go on systems with less than 1.5GB ?
  • »26.04.13 - 22:52
    geit,
    That is the first time I have heard that.
    So there is an advantage to having more then 1.5 GB?
  • »26.04.13 - 23:20
    Posts: 12572 from 2003/5/22
    As far as I understand, it's not about data but solely about address space. So even on Efika 5200B with only 128 MiB RAM, the 1.5 to 2.0 GiB address space range is used for PCI etc.
  • »27.04.13 - 05:41
    No. From a MorphOS perspective, there's no difference between having 1.5 GiB and 2.0 GiB physical RAM installed.
  • »27.04.13 - 05:47
    Thanks Andreas,
    Good clarification.
    Address ranges, not physical memory.
  • »27.04.13 - 12:54
