Does OWB support Google Chrome Frame that is required by var
    TomKeric
    Posts: 146 from 2013/2/18
    Anyone that can answer if OWB support Google Chrome Frame that is required by various webpages
    -If you've never failed, you've never tried -
  • »19.04.13 - 13:31
    Posts: 3311 from 2003/3/5
    Google Chrome Frame is an Internet Explorer plugin that effectively replaces the IEs HTML engine with that of Chromium. If a website requests you use that, you probably should change your user agent from IE to something more sensible :) ... or the website itself is horribly broken.
  • »19.04.13 - 13:41
