ntfs3g
    bash64
    Posts: 977 from 2010/10/28
    I have a volume that is 127gb.
    I cannot format it with ntfs3g:
    2.HD:Devs/DOSDrivers> mkntfs -f kr0 512
    Device is too small (255kiB). Minimum NTFS volume size is 1MiB
    I removed the encryption and tried to format using the device assign name:
    2.HD:Devs/DOSDrivers> mkntfs -f usbscsi0.2 512
    Device is too small (255kiB). Minimum NTFS volume size is 1MiB.
    Any ideas?
     :-D
    P.S.
    I instlalled ntfs3g and FUSE using Grunch.
    [ Edited by bash64 16.04.2013 - 10:38 ]
  • »16.04.13 - 10:50
    Leif
    Posts: 111 from 2006/5/31
    Try without the "512" part . No idea what that is supposed to achieve.
    And always give the device name, not the volume name.
  • »16.04.13 - 12:18
    bash64
    That worked, but it did not work earlier. Not sure why.
    >mkntfs -f usbscsi0.1
    The 512 is the optional number of sectors.
    I used mounter to create a mountlist and dropped it into devs/dosdrivers.
    On reboot the drive is there but it says there is zero bytes free.
    I am trying a long format....
    Also, sometimes on reboot the drive comes up as usbscsi0.2.
    This makes this mountlist fail.
  • »16.04.13 - 12:41
    Leif
    If it says zero bytes free thern it is the built-in ntfs filesystem of morphos that is active.
    No need to use mountlist.
    You can use the automatic mounting as described in the readme.
    Automatic mounting
    Example System settings / Mount options:
    MBR Type: 7
    Filesystem ID: 0x4E544653
    Driver: L:NTFileSystem3G
    Buffers: 32
    Mountpriority: 5
    Control: noatime
    Additionally, under MorphOS 3.x, Edit
    Sys:Prefs/Env-Archive/sys/filesystems.conf
    Change the line
    DosType=0x4e544653 Filesystem="L:NTFileSystem" Name="NTFS"
    Into
    DosType=0x4e544653 Filesystem="L:NTFileSystem3G" Name="NTFS"
    [ Edited by Leif 16.04.2013 - 18:52 ]
  • »16.04.13 - 13:50
    bash64
    thanks
    missed the env-archive editing.
  • »16.04.13 - 16:42
    bash64
    ok, all is working now.
    I could not format using the mkntfs tool that came with ntfs3g even though it said it did format.
    I hooked the drive up to windows and it said it needed to be formated so I did and put it back in the amiga and it worked.
    I was using truecypt so I did need to format the assign kr0 and not the device. formatting the device blows away the encryption. I know, I tried it.
    When partitioning or formatting and using kryptos always perform the operation on the kyrptos volume which by default is kr0:.
    So it hurts my feelings none that windows had to do the formatting.
    I have an encrypted volume that is formatted with ntfs and is using the ntfs3g read/write filesystem driver.
    Not sure why the mkntfs command couldn't get the job done.
  • »16.04.13 - 17:47
    bash64
    I have been on a quest ever since I bought an Efika, then a Quickcilver and now a Powerbook to make the Amiga do everything I do on the Windows machine.
    I am nearing the end of my quest.
    Would be nice if I had OpenOffice.
    I understand that there was a Word Processor that had support for Microsoft documents.
    Anyone remember the name?
  • »16.04.13 - 20:17
    Posts: 12570 from 2003/5/22
    http://www.haage-partner.de/amiga/amigawriter/aw2_new_e.htm#MSWord
  • »16.04.13 - 20:41
    bash64
    http://desler.be/modules/wfchannel/index.php?pagenum=4
    Anyone ever take up the author of Cinnamon Writer to port to MorphOS?
  • »17.04.13 - 09:32
    kas1e
    Posts: 97 from 2005/10/31
    He works on it all the time, few days ago i test mos/os4 betas
  • »17.04.13 - 09:56
    bash64
    I will beta if he wants.
     :-D
  • »17.04.13 - 10:10
    Leif
    Worked here.
  • »17.04.13 - 12:06
