Osx fail to upgrade on dualboot macmini
    Mabo
    Posts: 67 from 2010/5/3
    Hi folks!
    Osx asks me an upgrade from Leopard.X to Leopard.Y
    Osx says it has to reboot the system to update, and failed (with a bar that does not go forward) I guess that it see the dualboot not being in osx primary bootstrap plant.
    Thanks for your help.
  • »12.04.13 - 12:36
    boot_wb
    Posts: 874 from 2007/4/9
    I had a similar problem trying to apply updates on a Powermac MDD dual 1.42GHz (standard single-booting Leopard, no MorphOS installed).
    I ended up reinstalling Leopard and reapplying the updates. That Combo update did take a long time though. I ended up leaving it overnight, and by morning it had automatically rebooted and updated correctly.
    Don't think I ever bothered updating OSX on the mac-mini.
    www.hullchimneyservices.co.uk
    Windows free since 2011!
  • »12.04.13 - 16:13
    ausPPC
    Posts: 543 from 2007/8/6
    Has anyone tried segregating OSX onto a firewire drive? Do updates work properly that way or do the 'weird' partitions on the internal drive still get picked up and cause a problem?
  • »12.04.13 - 20:27
    Posts: 12570 from 2003/5/22
    Zylesea has.
    https://morph.zone/modules/newbb_plus/viewtopic.php?topic_id=6915&forum=11&start=18
    https://morph.zone/modules/newbb_plus/viewtopic.php?topic_id=7741&forum=11&start=6
    https://morph.zone/modules/newbb_plus/viewtopic.php?topic_id=8985&forum=11&start=7
  • »12.04.13 - 21:04
