ZoneXplorer 1.1.1
    Posts: 66 from 2003/10/5
    I would like to announce to every ZoneXplorer users that since some days version 1.1.1 is ready for download from ZX's home page (www.elena-fractals.it/zx.htm).
    I'm very displeased to see that ZoneXplorer link has been removed from the links section on www.morphos-news.de and when 1.1.1 was released I posted this new but it has perhaps been refused.
    If there's something against me please contact me privately so we can discuss.
    I worry not much for me rather for the users, since MorphOS software is actually very few and it's not a good thing to obscurate the news and the links about.
    Best regards,
  • »13.10.03 - 11:59
    cecilia
    Posts: 459 from 2003/8/30
    i sincerely doubt anyone has anything against you. it's probably an oversight.
    in any case i downloaded the new version! thanks!! :-D
  • »13.10.03 - 13:45
    tokai
    Posts: 1289 from 2003/2/25
    Hi Elena...
    no, the link was not removed... zoneexplorer is there:
    http://www.morphos-news.de/software.php?lg=en&md=gfx&sd=fract
    But on the startpage only recent links are listed. That means if some new link is added then older links are not displayed anymore on the frontpage. No need to worry. :)
  • »13.10.03 - 14:04
    tokai
    oh... Elena, and why you use now a linux like revision system? On Amiga/MorphOS we have only version.revision and not version.revision.build. Just out of curiosity... :-)
  • »13.10.03 - 14:07
    zacman
    Posts: 86 from 2003/2/26
    Hi Elena.
    We didn't remove ZoneXplorer from the "Link"
    section. In fact the so called "new software"
    section only has links to the latest releases of
    any software. So if there is newer software
    available then it gets on top etc.
    ZoneXplorer is still (and will always be) linked here.
    Maybe I have just overseen your news entry in my
    email folder, if that was the case I'm sorry. I
    have now updated the version number and date of
    ZoneExplorer so it'll be updated in the new
    software zone too.
  • »13.10.03 - 14:10
    There was a mistake and it has been clearified :)
    About the linux revision logic... please, how
    should I call this little improvement over 1.1 ?
    I think 1.2 was too much... 1.11 is even greater
    than 1.2. Perhaps 1.1a 1.1b 1.1c etc. ?
  • »13.10.03 - 14:47
  • Targhan
    Posts: 2833 from 2003/2/8
    1.1a, 1.1b, etc works for me.
  • »13.10.03 - 14:58
    Robin
    Posts: 741 from 2003/2/24
    It's a too big download to try.
    Does ZoneXplorer still require Reaction GUI system ?
  • »13.10.03 - 15:38
  • Targhan
    It uses ClassAct, the predicessor to ReAction.
  • »13.10.03 - 17:15
    Robin
    :-( Then I will wait a little longer ...
  • »13.10.03 - 18:54
    ikir
    Posts: 77 from 2003/7/24
    I'll post the news on the Ikir Sector... now 8-)
    Good work Elena.
  • »18.10.03 - 10:50
    Wishmaster
    Posts: 342 from 2003/6/29
    It should be called version 1.2
  • »18.10.03 - 14:56
    cecilia
    i have the newest zonexplorere and it works great on my Winuae. but on the peg it says it can't open layout.gadget v40
    i put the same layout.gadget that is on my OS3.9 emulation into the system/classes/gadget/ dir it's a new version from 2001.
    still no go.
    what's up?
  • »11.11.03 - 01:17
  • Targhan
    Ugh. Cecilia, format your SYS: partition, boot from the CD, re-install MorphOS. Download and install ClassAct from the Aminet. Download, follow the instructions for the ClassAct expansion on the AWeb website.
  • »11.11.03 - 04:55
    cecilia
    i looked at all the system files and they are all exactly the same as the ones found on the 1.4 CD.
    I looked at the version numbers of all the files. So, i already have a 1.4 install.
    I placed the gadget files from classact33.lha in the system classes/gadget dir. plus, i added whetever gadget files i have working on my WinUAE.
    this pegasos 1 does not have those "april" chips. those little mouse ears, as someone called them.
    would this be the problem?
  • »16.11.03 - 20:12
