mOS 1.4 und REBOL/VIew
    _coliN_
    Posts: 70 from 2003/4/30
    Hallo!
    Neues Problem:
    Ist da irgendjemand, der REBOL/View mit MorphOS
    am laufen hat?
    Das normale REBOL (Core) funktioniert....
    Danke!
    Boris
  • »07.11.03 - 18:23
  • Targhan
    Posts: 2833 from 2003/2/7
    Beide arbeiten. Ich verwende R/Core mehr als R/View.
  • »08.11.03 - 01:22
    _coliN_
  • »08.11.03 - 07:41
    merko
    Posts: 328 from 2003/5/19
    Sorry, my German isn't that good, hope you understand a reply in
    English: It is possible to get it to work, if you have an old
    Workbench 3.1 or similar. You need to copy the files in fonts:_bullet
    and probably some font from fonts:_bullet_outlines too. I think also
    libs:bullet.library is needed. Use SnoopDos to find out exactly what
    files it's looking for, if it still doesn't work.
  • »08.11.03 - 17:34
    _coliN_
    Thanks for the hint!
    I will try it tonight...
    But hopefully there will be soon a MOS-Version???
    (see all the other discussions...)
    Greets! Bo
  • »10.11.03 - 11:17
