Gentoo Linux
    DJBase
    Posts: 745 from 2003/4/6
    Hat sich einer schon das Gentoo Linux angetan und erfolg gehabt ?
  • »01.09.03 - 21:56
    dholm
    Posts: 296 from 2003/9/1
    My german is rusty so I won't attempt to answer in it although I understand you just fine.
    I ported gentoo to the pegasos a couple of days ago. You can find a beta install kernel here: http://dev.gentoo.org/~dholm/ppc.html. You will also need an install cd, I recommend: livecd-g3-grp-1.4-cd1.iso. I also recommend getting livecd-g3-grp-1.4-cd2.iso to get your system up and running as fast as possible (it contains precompiled packages).
    If you hold off for a couple of days I hope we will be able to provide installcds that has pegasos support on them already and the powerpc installation guide will be updated to reflect the pegasos. (Ther are a couple of things to take into consideration when installing gentoo on the pegasos, like not installing a boot loader and some special kernel options you need to enable).
    //David Holm
  • »02.09.03 - 15:08
    DJBase
    I have tried with the live-ppc-1.4 CD (1 CD) but I guess it was the wrong one. It gives me some Input/Output errors and stop on the prompt wiht "Enter runlevel:".
  • »02.09.03 - 15:12
    dholm
    I used the livecd-g3-grp-1.4-cd1.iso when I created the install kernel.
    The guy who is official in charge of the livecds is working on an official Pegasos-enabled cd. Hopefully it will be ready really soon, it should make it much easier to install.
  • »02.09.03 - 15:42
    DJBase
    Ok I will give the livecd-g3-grp one a try. Thanks so far.
  • »02.09.03 - 16:42
