Einfach folgenden Teil aus dem Installskript loeschen:
(if (not (= 0 (BITAND #gui-options 3))) ( (if (not (exists "MUI:Libs/muimaster.library" (noreq))) (abort "You need to install MUI 3.8 before you can install GUI " "modules for MiamiDx.") ) (if (< (/ (getversion "MUI:Libs/muimaster.library") 65536) 18) (abort "Your installed MUI version is too old for MiamiDx. " "Please upgrade to MUI 3.8 or higher before installing MiamiDx." ) ) ))
