MOS 3.2
    Jeckel
    Posts: 133 from 2007/3/11
    I just installed MorphOS 3.2 on my PowerBook G4 and navigation through Ambient listers seems to be broken when the volume name contains a special character.
    When opening a lister for a volume "Vidéos" for example, it works, I can enter a drawer and so on. But as soon as I try to go back to a parent folder (using backspace or the navigation buttons), it does not work. Using manual path input (using "/" key) doesn't help.
    I have the same behavior with any volume containing a special character. Volumes with no special character does not have this issue.
    Filesystem is SFS.
    [ Edited by Jeckel 28.05.2013 - 15:00 ]
  • »28.05.13 - 10:59
    cip060
    Posts: 151 from 2010/7/30
    Where are the options of the new panels?
    how come when block panels panels moving again?
    When I create new panel and I put the program icons, the panel will lock up and the icon does not appear
    I have to reboot the system and then appears
  • »28.05.13 - 12:03
    Posts: 1094 from 2004/9/23
    cip060,
    Where are the options of the new panel?
    In Ambient preferences, where they belong
    Geit
  • »28.05.13 - 12:06
    cip060
    Found it I panicked and I had just installed I had not looked well thanks
  • »28.05.13 - 12:30
    rebraist
    Posts: 96 from 2011/4/6
    Yeah! And when can I install Mos 3.3? :-D
    I was joking!
    Great work dudes! Thx!
  • »28.05.13 - 13:11
    SoundSquare
    Posts: 1214 from 2004/12/1
    a friend of mine is giving me an XServe G5 dual 2,3ghz, any hope MorphOS would boot on it or are the internal components too different ?
  • »28.05.13 - 13:15
    Posts: 12552 from 2003/5/22
    https://morph.zone/modules/newbb_plus/viewtopic.php?topic_id=9217&forum=11&start=16 :-)
  • »28.05.13 - 13:34
