Review of MorphOS 2.1 / Test de MorphOS 2.1
    Daff
    Posts: 247 from 2003/4/5
    Le premier test complet du syst?me d'exploitation MorphOS 2.1 est disponible sur le site d'Obligement a l'adresse suivante :
    http://obligement.free.fr/articles/morphos21.php
    Le test revient surtout sur les nouveautes et les bogues corriges ou restants de cette version.
    Le tutoriel sur l'installation de MorphOS 2.0/2.1 a aussi ete mis a jour : http://obligement.free.fr/articles/morphos20_installation.php
    [ Edited by Daff on 2008/9/15 17:44 ]
    [ Edited by Daff on 2008/9/16 20:31 ]
  • »15.09.08 - 14:43
    tokai
    Posts: 1289 from 2003/2/25
    A few remarks...
    I'm sad you don't like the new shortcut and appicon identifiers. :-) They are not 2-coloured, if you look with Zoom you will see they are carefully antialiased. Black and white was used for usability aspects, so they work no matter how your wallpaper/ desktop background looks like. They will stay in strong contrast if the wallpaper is bright or dark.
    The old appicon identifier was just a dummy and had completly pointless visual symbolic (the old image symbolizes a Shell/CLI). Further it was far too big and covered too much of the icon. For the old shortcut arrow many complains were received how ugly it is.
    Anyway.. this is not hardcoded/fixed, you simply can use your own images for them (don't know the filenames right now, but i'm sure Fab or kiero can tell you). I personally think the new images serve much better as defaults than the old stuff.
    About NList stuff.. I removed it -after long discussion in the team- for different reasons.
    First of all it's completly unmaintanable mess. The maintainers rather discuss how OS4 rules must apply to the other C=-AmigaOS-alike OSes than accepting simple patches which is highly time-consuming for no reason.
    Further same maintainers make other applications (namely YAM) require always the latest *minor* version of the classes for no functional reason which should concern the users. Hence the applications would quickly fail to start on a vanilla MorphOS 2.1 system (again for no real reason).
    The final reason is that I would see 3rd party developers make their new MorphOS applications not depend on some rather obscure and superflous 3rd party custom classes. A good application works on a plain 2.1 installation w/o requiring additional classes/ setup or installation procedure.
    I didn't know Sputnik needs NList (started fine for me). That's something which needs to be fixed obviously. Time to force Marcik to do some work again. :-)
    regards,
    tokai
  • »15.09.08 - 15:54
    Daff
    Ok, thanks for the feedback.
    - For NList/Sputnik, it's an error. Sputnik can be laucnhed without NList (I've fixed it in the review).
    - For appicon identifier : it's perhaps better to let the user define his preference about that. Why not do the same as the pointer choice ? (with several identifier : bright, dark, contrasted, colored, big and colored,...).
  • »16.09.08 - 02:07
    tokai
    Like I said the images are completly user configurable already. You just need to copy your own images to the Ambient image dir (with the right filename).
    I don't think it makes sense to add another option to the already bloathed up with useless options Ambient prefs GUI just for the sake of it to configure the internal default. ;-)
    regards,
    tokai
  • »16.09.08 - 09:18
    Posts: 2070 from 2003/6/4
    Les links son mort. -> 404
  • »16.09.08 - 11:31
    Daff
    Zylesea : MorphZone forum engine have capitalized the "m", "o" and "s" of "morphos" in the adress. So the link are not reacheable.
    Put all in minus letters not in capital letter.
    [ Edited by Daff on 2008/9/16 20:36 ]
  • »16.09.08 - 17:35
