Website Bugs
    connor
    Posts: 650 from 2007/7/29
    Last link mentioned this one:
    EDIT: Had to fix quotes YET AGAIN because the poster is unable to properly use them.
    [ Edited by ASiegel 19.01.2014 - 19:05 ]
    If the forum software cannot handle these errors then it would be needed to handle them better. In other forums that I remember a "wrong" quoting does not break the layout.
  • »18.12.24 - 14:28
  • ASiegel
    Posts: 1397 from 2003/2/15
    KennyR wrote:
    Broken link posting.
    For example
    http://amiga-news.de/de/news/AN-2022-07-00068-DE.html
    The "-" gets replaced by a smiley face and the link breaks. Adding it using the url= code completely breaks it
    This issue was resolved.
  • »08.06.25 - 09:09
  • ASiegel
    [quote]connor wrote:
    If the forum software cannot handle these errors then it would be needed to handle them better. In other forums that I remember a "wrong" quoting does not break the layout.[/quote]
    [/quote]
    The forum software should handle irregular quotation tags a bit better now, i.e. they are not converted to HTML. (See above.)
  • »08.06.25 - 09:33
