Posts: 1193 from 2003/2/24
MorphOS's smoothness on PUP highly depend on the MUI skin in use. The default skin is somewhat bloated, using a lighter MUI skin helps a lot.
If I recall correctly, default settings also were configured to use a font that's missing from the release, which will also make the system slower (as it will try locating the font now and then)
