MorphOS Library updates
    Posts: 537 from 2003/4/11
    In fact, there is even a FreeScale/NXP document describing the Pegasos Firmware:
    Genesi Pegasos II Firmware
  • »04.09.18 - 19:51
    Papiosaur
    Posts: 2042 from 2003/4/10
    This document is available on MorphOS-Storage too :
    http://www.morphos-storage.net/Documentation/Pegasos/Genesi_Pegasos_II_Firmware.pdf
    Thanks jPV for this news articles, i will try to translate in French soon.
  • »04.09.18 - 20:23
    Posts: 1224 from 2010/1/6
    I know all these documents, but they are useless for that issue. We need deep internas of FW to do this (Hardwareaddress, location of Filesystem, Syntax to access, and so on). The only one I know, who knows about, is Nicolas Det from Bplan. AFAIK he did a lot to implement FW on Pegasos.
  • »04.09.18 - 20:33
    Actually, the Efika firmware version is more advanced than the one found in Pegasos2. And no, you don't need deep internas of its F/W to get USB massstorage working on Peg2, it simply doesn't support massstorage, get along with it ...
    Nicolas Det indeed worked for Bplan and last but not least implemented some FW related code (mostly for Efika, though). The relevant parts in Pegasos2 F/W never got updated, though.
    But I didn't want to get off topic here, jPV has without a doubt done a great job updating MorphOS Library with this articles.
  • »04.09.18 - 23:06
    Posts: 12074 from 2003/5/22
    > pegasos 2 revision 2b6
    2B5 was the last revision.
  • »05.09.18 - 00:32
    Posts: 2794 from 2006/3/21
    jPV wrote:
    Added the Ssh2FS tutorial:
    https://library.morph.zone/Mounting_Network_Drives#Ssh2FS
    And:
    Using Multi-display Setups
    Thanks to NewSense for proof-reading!
    Also updated unofficially supported machines to the Supported Computers list.
    Zukow has also added:
    Using the New Printing System
    Thanks for all of your work on these articles for MorphOS Library! It is greatly appreciated to have this resource to help users. If you ever need more proof reader help in the future, I would gladly do proof reading of English documents and try to get them returned within 24 hours or less.
  • »18.11.19 - 00:27
    Posts: 888 from 2004/1/24
    Nice article and at that:
    Diavolo Backup for MorphOS
    [ Edited by Stevo 31.03.2023 - 22:22 ]
  • »31.03.23 - 21:22
