I can only send empty PMs
    Fats
    Posts: 19 from 2011/2/3
    Seems I can only send empty PMs with only title.
    I am on Linux (CentOS6). Tried both from opera and firefox.
    Trust me ...
    I know what I am doing
  • »21.12.12 - 13:45
  • ASiegel
    Posts: 1397 from 2003/2/15
    Anybody else with the same problem?
  • »21.12.12 - 14:04
    Samurai_Crow
    Posts: 198 from 2009/12/10
    Tried posting from Chrome on my Mac and it worked fine. Fats, you've got a PM entitled "Test Message".
  • »21.12.12 - 14:42
    boot_wb
    Posts: 874 from 2007/4/9
    Appears to work ok from OWB on MorphOS 3.1 (assuming it's received ok).
    www.hullchimneyservices.co.uk
    Windows free since 2011!
  • »21.12.12 - 15:51
    Fats
    @Samurai_Crow
    Did you try to add a body text ? I only saw the title; and that is what also worked for me.
    I replied to your message with a body.
    [ Edited by Fats 21.12.2012 - 18:29 ]
    Trust me ...
  • »21.12.12 - 16:26
  • ASiegel
    @ Fats
    I can confirm the issue. It's being investigated.
  • »21.12.12 - 16:45
  • ASiegel
    Okay, the problem should be solved. Thanks for pointing this out.
  • »21.12.12 - 18:40
    Fats
    @ASiegel
    Thanks for the quick fix. Seems to work OK now.
    Trust me ...
  • »21.12.12 - 19:29
