Morphzone bugs/translation errors
    boot_wb
    Posts: 874 from 2007/4/9
    Just a couple:
    1) In Private Messages > Config
    The "Sent message on specially side indicate:" option toggles incorrectly. "Yes" hides the sent messages, "No" shows the sent messages (On the Private Messages page).
    2) In Private Messages > Config
    "Sent message on specially side indicate:" seems like a poor Altavista Babelfish translation, and should probably read something like "Show sent messages:".
    3) In Private Messages
    "Profile>Message Exit" should probably read "Profile>Sentbox" (AV Babelfish again?)
    1) is the only real 'bug';
    2) and 3) I just couldn't let pass without mentioning. ;-)
    Regards
    Rich
    [ Edited by boot_wb 17.02.2012 - 00:39 ]
    www.hullchimneyservices.co.uk
    Windows free since 2011!
  • »16.02.12 - 23:38
  • ASiegel
    Posts: 1397 from 2003/2/15
    boot_wb,
    1) is the only real 'bug'; 2) and 3) I just couldn't let pass without mentioning.
    These issues have been fixed.
  • »17.02.12 - 15:47
    boot_wb
    @ASiegel
    Thanks!
    Another one which has been mildly annoying me for a while:
    After posting a reply in a topic which has >1 page, the redirect takes the user back to Page 1 of the topic (it would be more useful to return the user to the final page, preferably to the newly-submitted post).
    I hope this is helpful, and not taken as negative criticism. I do appreciate the work you put in to create this site for us. :-)
  • »24.02.12 - 21:51
