Honorary member
    Jupp3
    Posts: 1193 from 2003/2/24
    I noticed we have a honorary member for this month(?) (and he definitely deserves it)
    Was just thinking if that could be a "(bi?)monthly vote" between people having done generous donations, having done nice ports or original programs/games (quality/quantity) or something else?
    What do you think? Would this work / be a good idea?
  • »14.11.06 - 04:52
    hooligan
    Posts: 1948 from 2003/2/23
    My original idea was that the "Honorary member of the month" shouldnt be necessarily every month, but only when someone truly deserves the award.
    But I do like the idea of a votingsysten every now and then.
  • »14.11.06 - 05:14
    Stingray454
    Posts: 18 from 2006/8/23
    First of all, I certainly agree that AmigaHarry really deserves to be honorary member :)
    I also think that the voting idea is an ok solution. However I don't think you should limit it to one member (as "member of the month" implies). As for example, with Marcik releasing the first KHTML-browser he is a candidate also, but one does not exlude the other ;)
    EDIT: As a sidenote, the "honorary member"-button displays with an ugly gray frame around it in IE - perhaps the image should have a white background instead of alpha to look ok :)
    [ Edited by Stingray454 on 2006/11/14 9:35 ]
    [ Edited by Stingray454 on 2006/11/14 12:46 ]
  • »14.11.06 - 06:23
    hooligan
    EDIT: As a sidenote, the "honorary member"-button displays with an ugly gray frame around it in IE - perhaps the image should have a while background instead of alpha to look ok :)
    Yes, that needs to fixed. Also maybe it would look better if the medal was in the middle.
  • »14.11.06 - 07:15
    Posts: 108 from 2005/4/3
    Hi all,
    AWeb, the "Honorary member" image is displayed without gray reqtangle !
    Grts, Amigaharry
    http://www.angelfire.com/amiga/ex
  • »14.11.06 - 15:37
    zacman
    Posts: 86 from 2003/2/26
    Looks fine in IE7 on Vista.
  • »14.11.06 - 16:19
  • ASiegel
    Posts: 1396 from 2003/2/15
    @ stringray454
    It is part of a secret ploy to make people use Sputnik on MorphOS instead of IE6 (and below) on Windows  8-)
  • »14.11.06 - 16:37
