Broken downloads on MZ - Thanx :)
    Posts: 919 from 2004/1/24
    @all
    Since the last major MZ server breakdown, a lot of files where moved and in most cases the links where adjusted accordingly...though there are still some b0rked ones. I want to thank the ppl that bother to report those links, so we can try to restore (or remove) them. And since I get anonymous reports most of the time, a public "thank you" is in order :-)
  • »15.08.06 - 20:28
    ...and thank you cecilia for another 4 reports :-D (though three of them work here, maybe a proxy issue?)
  • »15.08.06 - 22:29
    cecilia
    Posts: 459 from 2003/8/30
    i don't think i am using a proxy.
    but if they work at your end, then it's ok. I just figured I'd check for the heck of it!
    i'm looking forward to the gallery being fixed - but don't consider this "nagging". there's no rush.
  • »16.08.06 - 12:49
    Gelb
    Posts: 148 from 2003/3/4
    How about just verifying if you are, so that everbody can be certain the mistake was on your end so that, most importantly, Stevo can sleep through a whole night again since the link issue was brought up? :-)
    No! No rush please!!!1 The gallery is just going into it's third year of being either not present at all or being a joke called minigallery (picture submission thread anyone?). :flame:
    So, don't consider this nagging either, its just only 2 years now. Take your time! :angel:
  • »16.08.06 - 13:46
    Another 8 files fixed; thank you Visitor :)
  • »16.08.06 - 17:16
    cecilia
    well, aren't YOU a happy camper!
    anyway, I've never done anything to my browsers to turn on "proxy". Not that i even really know how. You'll have to excuse me, but not everyone here is a tech-nerd.
    I'm mearly a humble artist. 8-D
    I normally use Opera - Version 7.21 (in case you care) and have never touched anything that calls itself 'proxy'.
  • »16.08.06 - 22:06
    Another 11 reported files...but all checked out fine. Keep 'em coming though :-)
  • »17.08.06 - 18:51
