Login timeout
    Posts: 1086 from 2003/3/24
    Targhan could you please set the login time up.
    It's very annoying to log in every 30 minutes or every hour.
  • »15.09.05 - 21:05
  • Targhan
    Posts: 2833 from 2003/2/7
    @ThePlayer
    What browser, and what settings? This doesn't happen here, so there has got to be some kind of disagreement between the site and your browser. If we can get some of the particulars, the browser and the site can be forced to hug and make up.
    :idea:Targhan
  • »16.09.05 - 14:28
    I use IBrowse 2.3, and all cookies are acepted.
  • »17.09.05 - 11:10
  • Targhan
    Aha! I think I found a problem! When I did the last engine update, the installer renamed the MZ cookie to the default engine cookie name. This would for sure log you out if you visit another site. I've just renamed the cookie, so that problem should be gone now... Sorry to anyone online at this exact instance, because you just got logged out :lol:
    :idea:Targhan
  • »18.09.05 - 15:01
    Markus_Bieler
    Posts: 19 from 2004/3/20
    It seems, that the problem is back. I just logged in, replied to a entry, and got the msg you are not logged in. I relogged. Wrote the same again. And was just logged out.
    I have to hurry, to post.
    :angel:
  • »07.03.06 - 20:29
    LOL no problems here.
  • »07.03.06 - 21:57
    Markus_Bieler
    Not very funny when you typed in a long text just to see you have been logged out before. I really have about a minute time to make a reply.
    I deleted all cokies, but it just happned before again.
    :angel:
  • »07.03.06 - 23:30
