"Did you know" tips
    winterhunter
    Posts: 204 from 2005/10/13
    Is there some "compilation" of all the "Did you know?" tips that
    appear under the user menu? There are lots of small "tricks" that one
    can learn, and having them under a single file for reference/printing
    could be a huge help for newbie like me!
  • »10.01.06 - 19:08
    Sergio
    Posts: 91 from 2005/2/16
    BTW, I see some "Did you know?" entries for Ambient, it would be nice to have some for Scalos too.
  • »11.01.06 - 08:34
  • Targhan
    Posts: 2833 from 2003/2/7
    Currently, there is no complete list of "Did You Know" available, but that can be arranged.
    I think the Scalos idea is a very good one, but I would need express permission from the author and likely the first half-dozen or so tips provided. (This way I can give credit to the proper person for at least some of the tips before we get user tips!)
    Also, Don't forget to visit the sticky topic for the tips to add some others!
    :idea:Targhan
  • »11.01.06 - 15:56
