CPU Temperature
    GK_LKA
    Posts: 481 from 2004/3/28
    Is there any way to determine how high is the temperature of the CPU? I have random crashes, and I really don't know what causes them... :/
    [ GK / LKA Team ]
  • »11.07.04 - 19:46
    Posts: 54 from 2004/6/16
    This popped up elsewhere, the only way is to put a thermometer of some sort on the CPU (or use your finger to guage it!). Perhaps a digital meter mounted on the outside, with sensor on the CPU/heasink with heat transfer compound? (something like this?)
    There is a teperature sensor in G3 and G4 processors, but they give very inaccurate feedback ...
    [ Edited by Holley on 2004/7/11 23:41 ]
    -~= Amiga Cats don't get Microsoft worms! =~-
  • »11.07.04 - 20:41
    GK_LKA
    I always dreamed of CPU-temperature display in my statline, like on linuxpc's... :(
    [ GK / LKA Team ]
  • »11.07.04 - 21:17
    Posts: 81 from 2004/3/20
    One of the things the powerpc processors are known for is low temperature operation. I believe if you go to pegasosppc.org, there is a temperature comparison chart between the powerpcs and some standard other processors. I've never had problems in mine and I've got my case loaded.
    Harry
    Config: Pegasos II G4 1ghz, 1024mb memory,
    Radeon 9200,160gb hd total, Sound Blaster Live!
  • »11.07.04 - 21:58
    Bifford
    Posts: 283 from 2003/2/24
    HarryO43 - I suspect those temperatures are under "normal stress" conditions. That is general use when the CPU isnt doing a lot of work.
    I would expect that with any computer (like mine) that runs RC5-72 and/or does things like 3D rendering or sound/picture manipulation then the temperature would be a few more degrees than in that chart ;-)
    A proper temp gauge would be nice though!
    Bifford
    Bifford the Youngest
  • »12.07.04 - 06:04
    gunne
    Posts: 441 from 2003/2/25
    Hi GK_LKA
    What is the name of the software thats showing CPU-temperature on Linux PC ? And what is this software doing ?
    Gunne
    [ Edited by gunne on 2004/7/12 10:32 ]
    Best wishes, Gunne
  • »12.07.04 - 06:31
    tokai
    Posts: 1289 from 2003/2/25
    @GK_LKA:
    as soon as the functionality for getting cpu temperature is working in exec (maybe in MOS 1.5?) statline will have a placeholder for cpu temperature. Code is done, but it does not returns any value yet.
    regards,
    tokai
    and a small update for statline is coming soon. :-)
    [ Edited by tokai on 2004/7/12 10:35 ]
  • »12.07.04 - 06:35
    Posts: 2070 from 2003/6/4
    @ GK_LKA
    I did measurements with my G3 and a digital thermometer and discovered that the CPU runs quite hot. More than 60 C. And the Thermometer had only poor contact to the heat sink. My guess is that the core reaches 70C - 80C. Anyway the system runs stable I'm RCing now 48 hours without interruption and the system is still stable.
    IBM docs for the 750Cx(e) say the temperatur range is from 0C to 105C. the 7447 is also said to work with temperatures up to 105C...
  • »12.07.04 - 07:21
    Posts: 1082 from 2003/3/24
    My G4 is running now with 50.3C, Crunching RC5 since yesterday, my G3 was running with up to 63C. All measured with a digital thermometer between CPU and Heatsink!
  • »12.07.04 - 10:37
    GK_LKA
    Thanks for answers. So my CPU temp. is ideal, but then what is wrong in my system...? I have to look at the software side...
    [ GK / LKA Team ]
  • »12.07.04 - 10:53
    @Bifford,
    You're right. Would be nice to have something like the peecees motherboard monitor in place to measure temps from the system.
    Harry
  • »12.07.04 - 11:11
    AyoS
    Posts: 410 from 2003/8/13
    My G4 ran at about 53C until I bought a new Highspeed fan which I control with my AeroGateII. Now i crunch Dnet at about 32C, which is much closer to my liking. and my cpu fan only runs about 3600 rpm ( which isn't too noicy for me )
    Katos1
  • »12.07.04 - 11:22
    Yeah that fan on the G4 Card makes so much noise.
  • »12.07.04 - 11:37
