Just looking around
Posts: 15 from 2016/1/22
Hello, I am trying to post on the forum and to include an attached file, I get the follwoing error:
Error: 1: /var/www/morph.zone/modules/newbb_plus/cache/attachments/ n'existe pas ou n'est pas en écriture.
Can you please fix the problem. Moreover, can you add the txt extension as supported file type. It would allow me to post both of my two text files without needing to create a ZIP archive of them.
Thank you
»24.01.16 - 17:44
