Stylos - a new word processor
    Primax
    Posts: 220 from 2021/7/2
    ...then this is my suggestion for your next project! :)
  • »20.03.26 - 11:25
    tomasz
    Posts: 67 from 2026/2/11
    Primax wrote:
    Only then your word processor is s "complete success" :)
    Out of curiosity, I searched for information about IPP and came across an article about AirPrint on AmigaOS4. Since I have a Pegasos, I downloaded the program and was a bit shocked, as both my printers were detected and printing correctly. However, printing has always been the Amiga's Achilles' heel. While MorphOS has a great printing system, compatibility with a specific printer model is always an unknown. It turns out that all you need to do is check if the printer is AirPrint-compatible. It would be nice to have AirPrint on MorphOS.
  • »20.03.26 - 14:33
    tomasz
    Papiosaur wrote:
    ha yes... i have forgot this project...
    "The source code of Arild's airprint driver is based on the source code of the HP DeskJet CMYK sample driver, while the airprint.device is based on Chris Young's ipp.device Github link. The developer provided many useful hints on how the devices work together, enabling Arild to develop it further."
    Doesn't that sound like a challenge? ;-) Bounty?
  • »20.03.26 - 14:54
    Papiosaur
    Posts: 2623 from 2003/4/10
    This is the list of bugs found:
    FYI, each bug found and not listed entitles you to a €5 discount on registration (See readme file for more informations)
    PS: Bugs found must be send by mail please
    Bugs found by Sprocki: (fixed in 0.101)
    1. New Document keeps page count from previous document — creating a new document after a multi-page one still shows the old page count.
    2. Recent Documents menu contains empty entries — blank lines in the submenu after opening only one file.
    3. Find: Enter on second match deletes the found text — first hit works, next Enter deletes the selection instead of jumping to next occurrence.
    4. Find direction switch requires double keypress — after Cmd+B (backward), first Cmd+G (forward) is ignored.
    5. Replace closes the search bar without replacing — clicking Replace does nothing and closes the bar, whether replacement text is set or not.
    6. Font list breaks after DejaVu Sans — selecting any font after DejaVu Sans in the list applies DejaVu Sans instead of the chosen font. Font index mismatch.
    7. Bullet list dot size inconsistent — alternates between small and large dots on consecutive lines with mixed font sizes.
    8. Numbered list with large font overlaps previous line — number "2." at 72px paints into the line above; text on line 2 reverts to size 12.
    9. Strikethrough don't work via menu
    10. Undo/Redo don't work via hotkeys
    11. Print option via menu show nothing
    12. Search cannot find table entries
    13. Hyperlink insertion duplicating selected text
    14. Search only finds text inside tables if the table is already active (editing mode), or if the search term also exists in the normal text after the table. Otherwise, table content is
    skipped.
    Bug found by Thomas Igracki:
    1. Help key show a rectangle
    Bug found by skateman:
    1. Add a link to text, remove the picture located below
  • »21.03.26 - 11:55
    tomasz
    I think it would be nice to have autosave
  • »28.03.26 - 08:07
    NewSense
    Posts: 1618 from 2012/11/9
    If you are testing Stylos, then you would be well advised to delete any previous versions of Stylos's .prefs in Sys:Prefs/Env-Archive/MUI/ for each and every new version that you test, as some of the prefs conflict with later version(s) which can fail to load the Stylos GUI correctly, usually related to the Fonts List, but not exclusively!
  • »03.04.26 - 06:25
    Papiosaur
    @NewSense: Thanks to report this problem and propose a solution.
    Strange, because i didn't have this problems here from the beginning and i didn't have any ideas about the origin of the problem unfortunally. If somebody has any problem, don't hesitate to contact me.
  • »03.04.26 - 07:09
    tomasz
    Where can I find new versions of Stylos? It's no longer available on morphos-storage...
  • »26.04.26 - 14:58
    tomasz
    Great! I haven't updated the program since version 112, and I think I saw version 118 on MZ before, and it suddenly disappeared.
  • »26.04.26 - 17:22
    tomasz
    Thank you.
  • »27.04.26 - 08:14
    tomasz
    It's great to see the program's steady progress. Are you working on anything with the presentation software?
  • »31.05.26 - 04:38
    Posts: 1390 from 2010/1/6
    Oh - "High Speed" developement?
  • »10.06.26 - 08:43
    DanicaTalos
    Posts: 461 from 2010/10/15
    Great News! ❤️
    iBook G4 - 14" -1,42 GHz - 32MB VRAM - 1,5GB RAM - 60GB mSata - MorphOS 3.20
  • »10.06.26 - 16:10
    tomasz
    Papiosaur wrote:
    Hello,
    this is last version of Stylos (1.6) come with print support (IPP) and a new IPP-Print tool is include to print PDF for example.
    chapeau bas!
    A great word processor with a proprietary printing system! It found my printer immediately and printed beautifully.
  • »11.06.26 - 14:59
