IconEdit for MorphOS
    NewSense
    Posts: 1565 from 2012/11/9
    Just sent you a well deserved donation for all your efforts for this (and all the past) years, when you've done so much for the MorphOS community.
    Hope you manage to implement SVG icon editing into Iconos in the future? As that would be a really cool feature and a first for MorphOS. 8-)
  • »24.11.25 - 20:35
    Nadir
    Posts: 178 from 2003/3/17
    It should be much easier now with the help of ThorVG which should be part of upcoming MorphOS releases in the form of a shared library which exposes the C API. Have a look at that!
  • »25.11.25 - 06:04
    Posts: 12471 from 2003/5/22
    > i didn't understand it was allready integrated in MorphOS :-)
    If it's "now [...] in beta", then it will "be part of upcoming MorphOS releases" when it's out of beta. That's how things have always worked.
  • »27.11.25 - 22:01
    Samurai_Crow
    Posts: 197 from 2009/12/10
    Papiosaur wrote:
    - PNG support initially (we'll see about SVG later)
    When you're ready to ditch the XML overhead of SVG, the Haiku Vector Icon Format is now available using open source conversion utilities from https://github.com/threedeyes/hvif-tools and someone has already made an HVIF exporter for Inkscape.
  • »15.12.25 - 17:02
    Papiosaur
    Posts: 2492 from 2003/4/10
    Thanks for the info
  • »16.12.25 - 06:55
