Cross compiling for MorphOS apps
    Posts: 631 from 2004/4/15
    Hmm,
    for me bigfoots script does not work on Ubuntu 19.10 for some reasons.
    I have changed some lines, but now compilation of ggc9 fails with really trivial
    error (missing stdio.h).
    What I needed to change in bigfoots script:
    - it checks for an sdk lha archive (don't know if exists anywhere,
    but on morphos site there is only this archive sdk-source-20191006.tar.xz)
    I removed the lha parts because they don't seem to be required
    - make for gcc is called CFLAGS -m32 set. As I remember correctly, a 32 bit
    env is not required anymore, so I also removed this argument
    In the end I get the error above.
    I don't know if the correct script was put to public.
    That's the way I called the script:
    ./setup-cross-sdk.sh --gcc9 --force
    My changes: https://exdev.selfhost.eu/mos/setup-cross-sdk.sh
  • »18.10.19 - 20:54
    bigfoot
    Posts: 510 from 2003/4/11
    Marlon wrote:
    Have you checked out my script?
    No I haven't, sorry.
  • »19.10.19 - 06:57
    bigfoot
    eliot wrote:
    Hmm,
    Yes, it fails because of those changes :)
    The lha archive is required. It's on the MorphOS website. It's the regular SDK download, and it contains, among other things, stdio.h
    Only if it detects you're building an old SDK with an old version of Binutils that doesn't work when compiled in 64 bit mode, which won't be the case if you're compiling the latest SDK. No need to change that.
    It was. It just requires you to supply it with both files it needs, and to not make modifications to it.
  • »19.10.19 - 07:00
    @bigfoot
    Oh man, your are absolutely right.
    It seems that I threw away my brain yesterday evening.
    I am totally sorry, ...
  • »19.10.19 - 16:44
    bigfoot
    eliot wrote:
    @bigfoot
    Hey, as long as you got it to work in the end, I'm happy :)
  • »21.10.19 - 21:42
    the setup looks quiet well:
    andre@drax:~/tmp/test_mos$ /gg/bin/ppc-morphos-g++ --version
    ppc-morphos-g++ (GCC/MorphOS) 9.2.0
    Copyright (C) 2019 Free Software Foundation, Inc.
    This is free software; see the source for copying conditions. There is NO
    warranty; not even for MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.
    andre@drax:~/tmp/test_mos$ /gg/bin/ppc-morphos-g++ -v
    Using built-in specs.
    COLLECT_GCC=/gg/bin/ppc-morphos-g++
    COLLECT_LTO_WRAPPER=/gg/lib/gcc-lib/ppc-morphos/9.2.0/lto-wrapper
    Target: ppc-morphos
    Configured with: ../gcc-9.2.0/configure --target=ppc-morphos --with-plugin-ld=no --enable-languages=c,c++,objc,obj-c++ --prefix=/gg --with-sysroot=/gg --libexecdir=/gg/lib --oldincludedir=/gg/include --program-prefix=ppc-morphos- --program-suffix=-9 --enable-threads=posix --disable-bootstrap --with-pkgversion=GCC/MorphOS --with-bugurl=http://www.morphos-team.net/ --enable-version-specific-runtime-libs
    Thread model: posix
    gcc version 9.2.0 (GCC/MorphOS)
    But I cannot compile/link a simple hello world example.
    Calling
    /gg/bin/ppc-morphos-g++ hello.cpp -o hello -noixemul -O3 -std=c++11
    leads to an linker error because it misses pthread_mutex_unlock and other pthread stuff.
    Are any more env variables|parameters to be set?
    EDIT:
    Complete error message:
    andre@drax:~/tmp/test_mos$ /gg/bin/ppc-morphos-g++ hello.cpp -o hello -noixemul -O3 -std=c++11
    /gg/lib/gcc-lib/ppc-morphos/9.2.0/../../../../ppc-morphos/bin/ld: /gg/lib/gcc-lib/ppc-morphos/9.2.0/libnix/libstdc++.a(locale.o): in function `std::locale::_Impl::_M_install_cache(std::locale::facet const*, unsigned int)':
    /tmp/tmp.FhmnUA3YJF/gcc9/build/ppc-morphos/libnix/libstdc++-v3/src/c++98/../../../../../../gcc-9.2.0/libstdc++-v3/src/c++98/locale.cc:433: undefined reference to `pthread_mutex_unlock'
    /gg/lib/gcc-lib/ppc-morphos/9.2.0/../../../../ppc-morphos/bin/ld: /tmp/tmp.FhmnUA3YJF/gcc9/build/ppc-morphos/libnix/libstdc++-v3/src/c++98/../../../../../../gcc-9.2.0/libstdc++-v3/src/c++98/locale.cc:433: undefined reference to `pthread_once'
    /tmp/tmp.FhmnUA3YJF/gcc9/build/ppc-morphos/libnix/libstdc++-v3/include/ppc-morphos/bits/gthr-default.h:749: undefined reference to `pthread_mutex_lock'
    /gg/lib/gcc-lib/ppc-morphos/9.2.0/../../../../ppc-morphos/bin/ld: /tmp/tmp.FhmnUA3YJF/gcc9/build/ppc-morphos/libnix/libstdc++-v3/include/ppc-morphos/bits/gthr-default.h:779: undefined reference to `pthread_mutex_unlock'
    /gg/lib/gcc-lib/ppc-morphos/9.2.0/../../../../ppc-morphos/bin/ld: /gg/lib/gcc-lib/ppc-morphos/9.2.0/libnix/libstdc++.a(locale_init.o): in function `std::locale::global(std::locale const&)':
    /tmp/tmp.FhmnUA3YJF/gcc9/build/ppc-morphos/libnix/libstdc++-v3/src/c++98/../../../../../../gcc-9.2.0/libstdc++-v3/src/c++98/locale_init.cc:284: undefined reference to `pthread_once'
    /gg/lib/gcc-lib/ppc-morphos/9.2.0/../../../../ppc-morphos/bin/ld: /tmp/tmp.FhmnUA3YJF/gcc9/build/ppc-morphos/libnix/libstdc++-v3/src/c++98/../../../../../../gcc-9.2.0/libstdc++-v3/src/c++98/locale_init.cc:286: undefined reference to `pthread_mutex_lock'
    /tmp/tmp.FhmnUA3YJF/gcc9/build/ppc-morphos/libnix/libstdc++-v3/include/bits/basic_string.h:6177: undefined reference to `pthread_mutex_unlock'
    /gg/lib/gcc-lib/ppc-morphos/9.2.0/../../../../ppc-morphos/bin/ld: /gg/lib/gcc-lib/ppc-morphos/9.2.0/libnix/libstdc++.a(eh_alloc.o): in function `_GLOBAL__sub_I__ZN9__gnu_cxx9__freeresEv':
    /tmp/tmp.FhmnUA3YJF/gcc9/build/ppc-morphos/libnix/libstdc++-v3/libsupc++/../../../../../gcc-9.2.0/libstdc++-v3/libsupc++/eh_alloc.cc:338: undefined reference to `pthread_mutex_lock'
    /gg/lib/gcc-lib/ppc-morphos/9.2.0/../../../../ppc-morphos/bin/ld: /tmp/tmp.FhmnUA3YJF/gcc9/build/ppc-morphos/libnix/libstdc++-v3/libsupc++/../../../../../gcc-9.2.0/libstdc++-v3/libsupc++/eh_alloc.cc:129: undefined reference to `pthread_mutex_unlock'
    /gg/lib/gcc-lib/ppc-morphos/9.2.0/../../../../ppc-morphos/bin/ld: /tmp/tmp.FhmnUA3YJF/gcc9/build/ppc-morphos/libnix/libstdc++-v3/libsupc++/../../../../../gcc-9.2.0/libstdc++-v3/libsupc++/eh_alloc.cc:338: undefined reference to `pthread_mutex_lock'
    /gg/lib/gcc-lib/ppc-morphos/9.2.0/../../../../ppc-morphos/bin/ld: /gg/lib/gcc-lib/ppc-morphos/9.2.0/libnix/libstdc++.a(eh_globals.o): in function `_GLOBAL__sub_D___cxa_get_globals_fast':
    /tmp/tmp.FhmnUA3YJF/gcc9/build/ppc-morphos/libnix/libstdc++-v3/libsupc++/../../../../../gcc-9.2.0/libstdc++-v3/libsupc++/eh_globals.cc:145: undefined reference to `pthread_getspecific'
    /gg/lib/gcc-lib/ppc-morphos/9.2.0/../../../../ppc-morphos/bin/ld: /tmp/tmp.FhmnUA3YJF/gcc9/build/ppc-morphos/libnix/libstdc++-v3/libsupc++/../../../../../gcc-9.2.0/libstdc++-v3/libsupc++/eh_globals.cc:145: undefined reference to `pthread_getspecific'
    /gg/lib/gcc-lib/ppc-morphos/9.2.0/../../../../ppc-morphos/bin/ld: /tmp/tmp.FhmnUA3YJF/gcc9/build/ppc-morphos/libnix/libstdc++-v3/libsupc++/../../../../../gcc-9.2.0/libstdc++-v3/libsupc++/eh_globals.cc:145: undefined reference to `pthread_setspecific'
    /gg/lib/gcc-lib/ppc-morphos/9.2.0/../../../../ppc-morphos/bin/ld: /tmp/tmp.FhmnUA3YJF/gcc9/build/ppc-morphos/libnix/libstdc++-v3/libsupc++/../../../../../gcc-9.2.0/libstdc++-v3/libsupc++/eh_globals.cc:145: undefined reference to `pthread_key_create'
    /tmp/tmp.FhmnUA3YJF/gcc9/build/ppc-morphos/libnix/libstdc++-v3/include/ppc-morphos/bits/gthr-default.h:714: undefined reference to `pthread_key_delete'
    /gg/lib/gcc-lib/ppc-morphos/9.2.0/../../../../ppc-morphos/bin/ld: /gg/lib/gcc-lib/ppc-morphos/9.2.0/libnix/libstdc++.a(guard.o): in function `__cxa_guard_release':
    /tmp/tmp.FhmnUA3YJF/gcc9/build/ppc-morphos/libnix/libstdc++-v3/libsupc++/../../../../../gcc-9.2.0/libstdc++-v3/libsupc++/guard.cc:389: undefined reference to `pthread_mutex_unlock'
    /gg/lib/gcc-lib/ppc-morphos/9.2.0/../../../../ppc-morphos/bin/ld: /tmp/tmp.FhmnUA3YJF/gcc9/build/ppc-morphos/libnix/libstdc++-v3/libsupc++/../../../../../gcc-9.2.0/libstdc++-v3/libsupc++/guard.cc:426: undefined reference to `pthread_once'
    /gg/lib/gcc-lib/ppc-morphos/9.2.0/../../../../ppc-morphos/bin/ld: /tmp/tmp.FhmnUA3YJF/gcc9/build/ppc-morphos/libnix/libstdc++-v3/libsupc++/../../../../../gcc-9.2.0/libstdc++-v3/libsupc++/guard.cc:426: undefined reference to `pthread_mutex_lock'
    /tmp/tmp.FhmnUA3YJF/gcc9/build/ppc-morphos/libnix/libstdc++-v3/include/ext/concurrence.h:103: undefined reference to `pthread_once'
    /gg/lib/gcc-lib/ppc-morphos/9.2.0/../../../../ppc-morphos/bin/ld: /tmp/tmp.FhmnUA3YJF/gcc9/build/ppc-morphos/libnix/libstdc++-v3/include/ext/concurrence.h:103: undefined reference to `pthread_once'
    /gg/lib/gcc-lib/ppc-morphos/9.2.0/../../../../ppc-morphos/bin/ld: /tmp/tmp.FhmnUA3YJF/gcc9/build/ppc-morphos/libnix/libstdc++-v3/include/ext/concurrence.h:283: undefined reference to `pthread_cond_wait'
    /gg/lib/gcc-lib/ppc-morphos/9.2.0/../../../../ppc-morphos/bin/ld: /tmp/tmp.FhmnUA3YJF/gcc9/build/ppc-morphos/libnix/libstdc++-v3/include/ext/concurrence.h:283: undefined reference to `pthread_mutex_unlock'
    /tmp/tmp.FhmnUA3YJF/gcc9/build/ppc-morphos/libnix/libstdc++-v3/include/ppc-morphos/bits/gthr-default.h:700: undefined reference to `pthread_once'
    /gg/lib/gcc-lib/ppc-morphos/9.2.0/../../../../ppc-morphos/bin/ld: /tmp/tmp.FhmnUA3YJF/gcc9/build/ppc-morphos/libnix/libstdc++-v3/include/ppc-morphos/bits/gthr-default.h:749: undefined reference to `pthread_mutex_lock'
    /gg/lib/gcc-lib/ppc-morphos/9.2.0/../../../../ppc-morphos/bin/ld: /tmp/tmp.FhmnUA3YJF/gcc9/build/ppc-morphos/libnix/libstdc++-v3/include/ppc-morphos/bits/gthr-default.h:700: undefined reference to `pthread_once'
    /gg/lib/gcc-lib/ppc-morphos/9.2.0/../../../../ppc-morphos/bin/ld: /tmp/tmp.FhmnUA3YJF/gcc9/build/ppc-morphos/libnix/libstdc++-v3/include/ppc-morphos/bits/gthr-default.h:700: undefined reference to `pthread_cond_broadcast'
    /tmp/tmp.FhmnUA3YJF/gcc9/build/ppc-morphos/libnix/libstdc++-v3/include/ext/concurrence.h:282: undefined reference to `pthread_mutex_unlock'
    /gg/lib/gcc-lib/ppc-morphos/9.2.0/../../../../ppc-morphos/bin/ld: /tmp/tmp.FhmnUA3YJF/gcc9/build/ppc-morphos/libnix/libstdc++-v3/include/ppc-morphos/bits/gthr-default.h:853: undefined reference to `pthread_cond_broadcast'
    /gg/lib/gcc-lib/ppc-morphos/9.2.0/../../../../ppc-morphos/bin/ld: /gg/lib/gcc-lib/ppc-morphos/9.2.0/libnix/libgcc.a(unwind-dw2.o): in function `uw_init_context_1':
    /tmp/tmp.FhmnUA3YJF/gcc9/build/ppc-morphos/libnix/libgcc/./gthr-default.h:700: undefined reference to `pthread_once'
    /gg/lib/gcc-lib/ppc-morphos/9.2.0/../../../../ppc-morphos/bin/ld: /gg/lib/gcc-lib/ppc-morphos/9.2.0/libnix/libgcc.a(unwind-dw2-fde.o): in function `__register_frame_info.part.0':
    /tmp/tmp.FhmnUA3YJF/gcc9/build/ppc-morphos/libnix/libgcc/./gthr-default.h:749: undefined reference to `pthread_mutex_lock'
    /gg/lib/gcc-lib/ppc-morphos/9.2.0/../../../../ppc-morphos/bin/ld: /tmp/tmp.FhmnUA3YJF/gcc9/build/ppc-morphos/libnix/libgcc/./gthr-default.h:779: undefined reference to `pthread_mutex_unlock'
    /gg/lib/gcc-lib/ppc-morphos/9.2.0/../../../../ppc-morphos/bin/ld: /gg/lib/gcc-lib/ppc-morphos/9.2.0/libnix/libgcc.a(unwind-dw2-fde.o): in function `__register_frame_info_bases':
    /gg/lib/gcc-lib/ppc-morphos/9.2.0/../../../../ppc-morphos/bin/ld: /gg/lib/gcc-lib/ppc-morphos/9.2.0/libnix/libgcc.a(unwind-dw2-fde.o): in function `__register_frame_info_table_bases':
    /gg/lib/gcc-lib/ppc-morphos/9.2.0/../../../../ppc-morphos/bin/ld: /gg/lib/gcc-lib/ppc-morphos/9.2.0/libnix/libgcc.a(unwind-dw2-fde.o): in function `__deregister_frame_info_bases':
    /gg/lib/gcc-lib/ppc-morphos/9.2.0/../../../../ppc-morphos/bin/ld: /gg/lib/gcc-lib/ppc-morphos/9.2.0/libnix/libgcc.a(unwind-dw2-fde.o): in function `_Unwind_Find_FDE':
    collect2: error: ld returned 1 exit status
    EDIT2:
    Linking pthread does not help either:
    andre@drax:~/tmp/test_mos$ /gg/bin/ppc-morphos-g++ hello.cpp -O3 -std=c++11 -lpthread
    /gg/lib/gcc-lib/ppc-morphos/9.2.0/../../../../ppc-morphos/bin/ld: cannot find -lpthread
    [ Edited by eliot 26.10.2019 - 10:40 ]
  • »26.10.19 - 10:35
    bigfoot
    Seems like there's another bug in the GCC 9 Makefile in the SDK source code archive that I overlooked. I've updated https://bigfoot.morphos-team.net/files/setup-cross-sdk.sh to patch this bug before building GCC 9 now.
  • »26.10.19 - 10:52
    Thanks bigfoot, now everything is working like it should.
  • »26.10.19 - 11:50
    Hmm,
    I just recognized that currently only the gcc 9 is fixed.
    Gcc7 and 8 having the same problem as reported before.
    [ Edited by eliot 31.10.2019 - 17:01 ]
  • »31.10.19 - 18:00
    jarokuczi
    Posts: 22 from 2016/12/6
    Hello is there any chance to get updated Debian packages with the latest SDK?
  • »17.06.20 - 07:43
    amigadave wrote:
    This should be very useful for programmers who only have room for one system, if they can run MorphOS3.12 (unsupported) on their Quad G5 PowerMac, and then boot into Linux PPC64 to cross compile MorphOS software on the same machine. I'm assuming that the various versions of gcc that are now supported are available for Linux PPC64, so that all 4 cores can be used when cross compiling software for MorphOS3.12.
    If I'm only going to do Hollywood programming as a beginner for a while, will I benefit much by getting a Quad Core PCIe G5 PowerMac and running some version of Linux to program from, instead of just using the MorphOS version of Hollywood, and running it on my existing 2.7GHz G5 PowerMac, running MorphOS3.12? After I become fairly proficient at Hollywood programming, I do plan to go back to learning how to program in C/C++, but it might be many months before I need to do that. Depends on what programming projects I decide to attempt.
    That's a big jump, Hollywood to C/C++. C requires pretty extensive knowledge of the environment you're operating in.
  • »18.06.20 - 17:09
    BSzili
    Posts: 559 from 2012/6/8
    I tried to build the GCC9 cross compiler with the current April 2020 SDK and 1.9 setup-cross-sdk.sh script under Cygwin. The November 2019 SDK builds fine with the script, but the current one doesn't. I get this error in setup-cross-sdk.log:
    make: *** No rule to make target 'gcc-9.2.0.tar.xz', needed by 'gcc-9.2.0/.morphos-sources-stamp'. Stop.
    While building I looked into the temp directory, and I found gcc-9.3.0.tar.xz there, but apparently most of the patches and the Makefile is for GCC 9.2.0. Has anyone managed to build a GCC9 cross-compiler with the latest SDK? I remember the last SDK required some patches too in the setup-cross-sdk.sh script. Please advise.
  • »09.09.20 - 17:08
    Posts: 3192 from 2003/3/5
    9.2.0 patches should just apply to 9.3.0... That said I have absolutely no time to look into updating the SDK. Will not happen before 3.14 is out for sure.
  • »09.09.20 - 18:27
    BSzili
    Unfortunately the Makefile has some issue, because it downloads gcc-9.3.0.tar.xz, but it's looking for gcc-9.2.0.tar.xz to build. Thanks for the response, I'll stay with the November 2019 SDK until then.
  • »10.09.20 - 10:34
    I've done some reading of several Amiga C/C++ books, and had started writing a couple first experiments (like Hello World stuff) with C in the past, and it seems to make the most sense to go back to learning C/C++ after I get a good grasp of using Hollywood, if my purpose remains just wanting to create programs that run on MorphOS/AmigaOS3 + 4/ and maybe AROS. Learning how to code in 68k Assembler I would consider to be a "big jump" from Hollywood.
  • »10.09.20 - 17:33
    Are there any updates?
  • »12.12.20 - 08:24
    A new SDK is in the works... no ETA yet though.
  • »18.12.20 - 15:13
  • IKE
    IKE
    Posts: 150 from 2009/11/7
    That's great news!
    IKE
  • »19.12.20 - 18:51
    beworld
    Posts: 652 from 2010/2/10
    @jacadcaps it's possible to update libpng on next SDK ? thks
    PowerMac G5 Quad 2.5, IMac G5 2.1, PowerBook G4 1.5, MacMini 1.5
    My MOS ports
  • »26.12.20 - 17:06
    Piru
    Posts: 593 from 2003/2/24
    libpng will be the latest 1.2 version (1.2.59). Note that different libpng versions are not API/ABI compatiple, and we happen to rely on 1.2.
    However, if you need a specific version it is not hard to build it yourself. Typically you can then add -I to pull correct includes and -L to pull the correct link library when linking.
  • »27.12.20 - 02:12
    beworld
    @piru i talk about version 1.6.37,
    but if this last version is not compatible with that of the SDK, it does not matter, I have my own version, it was just to optimize my executable.
    Thanks for your answer, I now know why it's version 1.2 on the SDK now.
    My MOS ports
  • »27.12.20 - 07:32
    beworld
    hi all,
    Any update for Cross-compiling with last SDK (gcc 10) ?
    Thanks
    My MOS ports
  • »20.03.21 - 12:04
