Posts: 12558 from 2003/5/22
> It seams, that the header is some sort of encryption. Perhaps against disassemblers? :)
According to Laire (German), the encryption has been put in place to prevent the MorphOS components from running on older MorphOS versions. Without the encryption, the ELF binaries could be stripped and made to run on MorphOS 1.x (dependencies unconsidered).
