How detect MorphOS version? (esp v3 vs v2)
    ChrisH
    Posts: 167 from 2009/11/26
    As the title says, is there an easy way to detect which version of MorphOS is being used? Especially whether v3.x is being used or not? Or will I just have to check the version of some random library?
    My reason: I had forgotten that I'd added a work-around to PortablE for a datatypes memory-trashing bug present in v2.7, which I had been told would be fixed for v3.0 . I'd like to dynamically disable this work-around, since it introduces a small memory leak.
  • »10.10.12 - 17:20
    Posts: 1092 from 2004/9/23
    struct Resident *rt;
    ----if( ( rt = FindResident( "MorphOS" ) ) {
    --------version = rt->rt_Version;
    --------if( rt->rt_Flags & RTF_EXTENDED ) {
    ------------revision = rt->rt_Revision;
    This should help.
    In Shell you can do similar by performing
    Version MorphOS
    Geit
    [ Edited by geit 10.10.2012 - 20:39 ]
  • »10.10.12 - 17:33
