    BalrogSoft
    Posts: 171 from 2006/10/6
    Balrog Software - AmigaSkool.net
    Mac Mini - MorphOS 3.8 - G4 1.5Ghz - Ati 9200 64 Mb
    Efika - MorphOS 3.6 - Ati 9200 64Mb - 80 Gb HD
    Amiga 1200D - OS 3.9 - Blizzard 603e/240mh
  • »05.10.12 - 07:14
    Posts: 1076 from 2004/9/23
    You must use MUIA_Selected and not MUIA_Pressed when dealing with a checkbox.
    MUIA_Pressed should only used for button object notifications.
    Beside that is using ReturnID a bad behaviour. Better create a proper subclass and notify a class internal method.
    Geit
    [ Edited by geit 05.10.2012 - 10:22 ]
  • »05.10.12 - 07:18
    BalrogSoft
    I had defined a notify to change automaticly the state of other buttons, and it had the same problem with the first event, but after changing the notification to MUIA_Selected, it works properly, thanks you!
    [ Edited by BalrogSoft 05.10.2012 - 10:56 ]
  • »05.10.12 - 07:53
