MorphOS Developer
                Posts: 1520 from 2003/2/24
				If it doesnt freeze you could try to retrieve crashlog. Run getramdebuglog in shell and if ramdebug is enabled it stores morphos.log to your current dir. If that is not possible you can use serial cabel to see debug in real time. It is also possible retrieve debug log after reset but on some machines it requires tuning boot options.
You could also try to run it with Wipeout (gg:/tools/wipeout) to find out memory trashing.
Using memorylists (instead of TLSF allocator) can also reveal some memory trashing (see boot options).
