How find where SDK is installed?
    ChrisH
    Posts: 167 from 2009/11/26
    Can someone tell me how I can find where the MorphOS SDK is installed on a machine? (Specifically the "include" folder where I can install 3rd-party header files.)
    Ideally there would be an assignment, like maybe SDK:include ? If not, what about an EnvArc variable?
  • »21.02.11 - 17:50
    Posts: 2564 from 2003/2/24
    "cd gg:" should allways work.
    On default the SDK gets installed in a folder "Development" on your sys: partition.
  • »21.02.11 - 18:03
    Posts: 3300 from 2003/3/5
    The SDK when installed assigns SDK: to the install location. There's also a MorphOSSDK env variable containing the path.
    You should install 3rd party includes in SDK:gg/usr/include (or simply GG:usr/include). It's all detailed in SDK's readme file, I suggest you read it.
  • »21.02.11 - 18:08
    ChrisH
    @jacadcaps Quote:
    That's perfect, thanks!
    I didn't want to have to download the whole SDK (again), just to see if it was documented or not!
  • »21.02.11 - 18:18
    ChrisH
    @all
    One more quick question:
    Is LHA installed on MorphOS by default? (And available from the command path of course)
  • »21.02.11 - 18:23
    Yes, of lha is included of course and will be in the default path.
  • »21.02.11 - 18:29
    Piru
    Posts: 617 from 2003/2/24
    @ChrisH
    LhA is installed but you should update it to the latest version (LhA 2.7.10) available from here: http://www.morphos-team.net/downloads.html
    This update fixes the Y2011 problems.
    [ Edited by Piru on 2011/2/21 23:40 ]
  • »21.02.11 - 19:39
